cossie clutch change
Old Jul 5, 2004 | 10:38 PM
slowpoke's Avatar
slowpoke
Default cossie clutch change
4x4 saph changing the clutch soon so gearbox out job
change clutch
gearbox oil
fit quickshift gear knuckle
any other things that could do with changing as they might be worn etc ?
bushes etc etc ?
cheers.........matt
Old Jul 5, 2004 | 11:11 PM
SPADGE's Avatar
SPADGE
http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MESE:IT
Old Jul 5, 2004 | 11:14 PM
dave cos4x4's Avatar
dave cos4x4
thrust bearing.
hope you can get the bolts off,i could not get 1 off.
Dave.
Old Jul 5, 2004 | 11:27 PM
NMS Badboy^NUTTER^'s Avatar
NMS Badboy^NUTTER^
Front diff seal???
Old Jul 5, 2004 | 11:31 PM
dave cos4x4
Spadge, i got that kit, about Ł50 it cost.
could not be arsed fitting it.
Dave.
Old Jul 5, 2004 | 11:42 PM
slowpoke's Avatar
slowpoke
spadge i saw this last night on ebay
what does the kit do exactly m8 ?
is thrust bearing same as release bearing ?
SPADGE's Avatar
SPADGE
Dave.
Should have done mate makes a lot of difference if the originals are a bit worn!
Old Jul 5, 2004 | 11:44 PM
dave cos4x4
was a bit awkward to do.
Could not see how i could push out the metal outer edges of the bush.
the ones in was o.k though.
Dave.
slowpoke's Avatar
slowpoke
is it just me or is passion ford not updating itself
ie it say only 3 people veiwed and no replys
anyone else finding this ?
Old Jul 5, 2004 | 11:51 PM
SPADGE's Avatar
SPADGE
Hi mate
this kit replaces all the bushes that are in the gear linkage cradle!
The whole thing attaches to the gearbox via these bushes so if they are worn you will have a less positive feel to the gear change because there will be more play on the whole lot!
As far as i am aware the thrust bearing is another name for what most people call the release bearing yes!
Cheers Spadge...
Old Jul 5, 2004 | 11:52 PM
dave cos4x4
The board only gets updated every 5 mins i think.
Somethink like that anyway.
Dave.
SPADGE's Avatar
SPADGE
Dave.
A couple of sockets similar diameter to the metal part of the bushes and a vice are all that you need to get them out/in mate
Old Jul 5, 2004 | 11:58 PM
slowpoke's Avatar
slowpoke
will keep an eye out for your auction then jules
cheers.................matt
p.s how about the transfer box oil ?
Old Jul 5, 2004 | 11:59 PM
dave cos4x4
Dave.
Will remember to do them next time now.
Had them for about 1 1/2 years.
Dave.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
rex647
Mar 6, 2022 06:20 AM
JK12
33
Apr 26, 2021 12:09 PM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
cossirob
Sep 3, 2015 09:17 PM
