ACT gauge sensor fitment
Old Oct 15, 2005 | 07:20 PM
Rallyesport's Avatar
Rallyesport
Default ACT gauge sensor fitment
How is this sensor placed in the inlet? Anybody got pictures of this?
Old Oct 15, 2005 | 07:34 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
take small boost hose of charge carrier-throttle, poke the wire sensor in, about a third of an inch i'd immagine, place jubilee and boost hose back over it and bobs your aunt!
Old Oct 15, 2005 | 08:17 PM
Rallyesport
I'm not sure it will be leak free.
Old Oct 15, 2005 | 08:39 PM
Rick's Avatar
Rick
if it's sucha tiny hose - a small leak wont make shit all diff.
I would put it in the outlet of the intercooler - by far the most accurate reading.
Old Oct 15, 2005 | 08:46 PM
Rallyesport
It a small insulatated cable, like a small speaker cable. When putting it closest to the manifold I'll will get the temperature of the air the engine will get.
Old Oct 15, 2005 | 10:37 PM
vroooom ptssssh
It Wasnt Me!
Yea you want it as close to the throttle as possible to see the exact temp the engine gets!
The hose is very small, the rubber/silicone hose will squash round it, dont worry about a leak!
Ideally you want one, before and after the IC, to see hoe efficient your IC is, but in reality one is enough at the throttle!
Old Oct 16, 2005 | 01:52 AM
Micky's Avatar
Micky
Is this post a joke??? Just stick it in before the the butter fly on the throttle body,easy!!! Whats the next question....."Where do I put my spark plugs,any pic's???" Regards Micky
Old Oct 16, 2005 | 07:07 AM
Rallyesport
Stick your spark plugs up your ass.
Old Oct 16, 2005 | 07:49 PM
James Raby's Avatar
James Raby
I have a switchable ACT gauge
Has 2 wires for 2 readings
One is in the passenger side of the inlet manifold (at top) and the other is at the outlet for intercooler
Get the best of both worlds that way
Old Oct 16, 2005 | 07:56 PM
Rick's Avatar
Rick
The most accurate place is at ther outlet of the intercooler. By putting it in the engine bay, near the manifold, the sensor itself starts to heat up due to the radiant heat coming off from the engine. Very expensive sensors are specially designed to combat this - what u are trying to measure is temperature by conduction.
If you place it in the vacume pipe, u will also get dodgy readings. Air here is moving slowly, and easily picks up heat. The very fast moving large volume of air at the outlet of the intercooler does not pick up any radiant heat on it's way to the manifold. The senor is kept at air temperature, and can respond much more quickly to changes.[/quote]
Old Oct 16, 2005 | 08:59 PM
vroooom ptssssh
It Wasnt Me!
Old Oct 16, 2005 | 09:26 PM
AKRS1's Avatar
AKRS1
Okay mine is basically as close to the throttle body as possible and can clearly say i am getting dodgy reading of around 70 degrees which i know is not right maybe i might try putting it on the intercooler outlet but its not accurate as you want too really know what the temp is when its entering the engine or maybe i'll just bin the whole thing as its been pissing me of for months
Old Oct 16, 2005 | 09:28 PM
Red16's Avatar
Red16
quality reply
Old Oct 17, 2005 | 07:21 AM
Rallyesport
I seen some gauges have the sensor in a hose connection that you swicth for one of the connections on the inlet manifold. The sensor I got is flat and I tried to put it under the small hose between the charge carrier and the throttle, no leaks that I could hear.
Old Oct 17, 2005 | 08:51 AM
AKRS1's Avatar
AKRS1
there is no leaks but the sensor wire gets to hot
Old Oct 20, 2005 | 08:32 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
https://passionford.com/forum/viewto...142061#2142061
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
