BIG THANK TO POWER ENGINEERING AND PRO ALLOY :D
Old Oct 15, 2005 | 06:17 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default BIG THANK TO POWER ENGINEERING AND PRO ALLOY :D
Went o PE on thurs with the Fast Ford RS turbo, its been running like a pile of shit since we spent the companys money on it
anyway, we go down, toddy sets it up and makes it work, the engine was rebuilt soooo shodily it was comical
anyway, kent cvh35 cam, chipped ecu and a pace 1/2 width cooler, running 13psi it made 181bhp and 189lbft and 71 deg ACT
so me and new boy neil fit the pro alloy full width cooler, no other mods and it made 190bhp 201lbft @ 5066rpm! and ACT of 57 deg max
top fucking rod boys!!
oh, toddy said we can spank it up to 18psi next time but it was 7.30 pm and we all wanted to get gone.
should easily see 210bhp
handles like a bag of wank tho, and new brakes are now on the list
ps matt, we forgot to get some PE stickers, lob some in the post will ya
Old Oct 15, 2005 | 07:09 PM
GUZZLER's Avatar
GUZZLER
I'll get some stickers sorted
was that the ferarri not the loudest car you ever heard
Old Oct 15, 2005 | 07:16 PM
DanRSturbo's Avatar
DanRSturbo
57 Degrees ACT
Old Oct 15, 2005 | 07:22 PM
Ginge !'s Avatar
Ginge !
just finding my feet
what was the car reved too
thats a low power band there
whats the rev limit
Old Oct 15, 2005 | 07:35 PM
Rick's Avatar
Rick
ginge - pretty normal for std chipped cars - especially if no vernier on the pulley. small housing and std head. Prob flatlined rather than fell off.
Old Oct 15, 2005 | 09:16 PM
JamesH's Avatar
JamesH
Originally Posted by DanRSturbo
57 Degrees ACT
That's what I thought!!
Old Oct 15, 2005 | 09:26 PM
Ginge !'s Avatar
Ginge !
rick THAT low
fook me thats terrible
Old Oct 15, 2005 | 10:18 PM
richm's Avatar
richm
57 Degrees ACT
probably on a rolling road though to be fair.....
but it would be interesting to see how the GRS compares...
Old Oct 16, 2005 | 08:54 AM
CliffRS4's Avatar
CliffRS4
57 Degrees ACT
I have a GRS Evo 3 and it never goes anywhere near that on the rollers
Old Oct 16, 2005 | 08:55 AM
richm's Avatar
richm
57 Degrees ACT
Old Oct 16, 2005 | 09:04 AM
CliffRS4's Avatar
CliffRS4
57 Degrees ACT
Mind you it's having a 400bhp zetec built at the moment so I think that should give the intercooler a bit of shit so we'll see
DanRSturbo's Avatar
DanRSturbo
My Pace Charge Cooler never got anywhere near that when on Powers Rollers
And that made 202 @ 16 psi
Old Oct 16, 2005 | 09:08 AM
James Raby's Avatar
James Raby
at 57 degree, It's certainly an issue I'd be tryig to sort out, not like it's middle of summer now is it and expect those kind of temps
Old Oct 16, 2005 | 09:34 AM
Ginge !'s Avatar
Ginge !
also apart fromthe slightly lower act's does the car actually feel any different
Old Oct 16, 2005 | 10:08 AM
essexrsturbo's Avatar
essexrsturbo
Default Re: BIG THANK TO POWER ENGINEERING AND PRO ALLOY :D
Originally Posted by fudgeass
ACT of 57 deg max
fuk me thats high.. gona be losing of power with them temp's!
oh... just read your using a pro alloy cooler, that'll be the reason then.
Old Oct 16, 2005 | 10:19 AM
Ginge !'s Avatar
Ginge !
but them claws away
before we ask about water temps
Old Oct 16, 2005 | 10:41 AM
essexrsturbo
but them claws away
please dont, i dont think his guage would go that far
Old Oct 16, 2005 | 05:58 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
it could just have been where the temp sensor wire was, it was slotted in the samco by the TB so the charge carrier got hot from the heat of the engine.
car goes like a c*nt now tho
it was on the rollers too, i guess we need a proppa temp sensor to accuratly measure the ACTs then
Old Oct 16, 2005 | 06:09 PM
pee vee's Avatar
pee vee
71 deg ACT
ACT of 57 deg max
richm's Avatar
richm
that's a fair position for the Temp sensor Dan - it's the temperature of the air that the engine gets when all is said and done..
Old Oct 16, 2005 | 08:23 PM
Ginge !'s Avatar
Ginge !
the sensor is usually in the inlet so it would in theory be even higher
you sure you should be working ona mag doing techy things
Old Oct 16, 2005 | 09:38 PM
©hatter Box's Avatar
©hatter Box
u think 57 is bad u dont want to know what mine r with my pro alloy cooler mk2 waneis on the case to sort it out
Old Oct 16, 2005 | 09:40 PM
Ginge !'s Avatar
Ginge !
so the pro alloy cooler is the bollocks thing is actually a load of bollox
glad i know that know, ill stick to me rad tech then
Old Oct 16, 2005 | 09:42 PM
pee vee's Avatar
pee vee
edited, cos i realised i was talking shite! lol
Old Oct 16, 2005 | 10:09 PM
©hatter Box
for a the cosworth ur cant get any better ginge its the best about
but with the escort rs turbo s1 or s2 there still trying to sort it out for the hi powed cars if it no more then 180bhp ur ok lol
Old Oct 17, 2005 | 10:03 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
well we gianed 10bhp at the same boost by just fitting the cooler, and there is potential for a lot more...
Old Oct 17, 2005 | 11:07 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Unless you know the output of the fans, how can you say the ACTs are shite (unless of course your ACTs were recorded on the same rollers with the same fans )?
14°C difference between the Pace one and the Pro-alloy one is a significant real world improvement. As long as any further tests are carried out using the same rollers / fans, then all improvements made will be valid.
Comparing different rollers / fans is a waste of time and completely idiotic and it is impossible to make direct comparisons .
Old Oct 17, 2005 | 11:14 AM
DanRSturbo's Avatar
DanRSturbo
When my car was last setup, Chris had the fan's on for at least 20 mins before even switching the engine on and even after 4 or 5 run's, the temps were no higher then 30oc
When I go back, And get a healthy 18 psi put through, I'll ask him what sort of ACT's it's showing
Old Oct 17, 2005 | 04:18 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Oh dear.........
Old Oct 17, 2005 | 08:52 PM
Keith B's Avatar
Keith B
Rick - I had PE put a vernier on my S2 (with the std cam) and it made not 1bhp more than the using the std settings on a std pulley. Just incase anyone thought that its poorly timed from the factory like a Focus ST/SVT (on the zorst side)
Great advice from you as usual!
Old Oct 17, 2005 | 08:57 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
btw if those temps were in farenheight, what are they in degrees centigrade??
Old Oct 17, 2005 | 09:01 PM
Tony Turbo's Avatar
Tony Turbo
Tooooooooo low, impossible
But......
At least you are happy mate, that's what matters
Old Oct 18, 2005 | 09:06 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
to be honest tho, at full chat on the road you are going to be moving a shit load more air over the cooler than the fan on a rolling road can provide, so i guess we need to use a ACT gauge on the road to get a 100% accurate figure...
fuzzy
21
Feb 15, 2016 10:26 PM
cossynut2
Aug 19, 2015 11:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
Blown Hell
Aug 5, 2015 07:22 AM
Old ford
Jul 31, 2015 06:50 AM
