rs turbo cabs
hi just thought i would tell you all about my 1988 escort cabs
mint 90 spec seats
rs turbo bodykit and bonnet
radiant red
2.1 zvh calibra turbo pistons
t3 hybrid turbo
fiesta ofac mangement
beige injectors
superchip
31 actuator
piper t2 cam and vernier pulley
ported head
lsd gearbox with stage 1 clutch
pro alloy double capacity intercooler
magnex s/s exhaust
koni adjustable suspension all round
lowered 25mm
sitting on escort cossie rim
ford puma gearnob
i will post some pics as soon as i get chance
the engine was fitted last week so im still running it in but what sort of power do you guys recon it will be running when i can get it setup
mint 90 spec seats
radiant red
t3 hybrid turbo
beige injectors
superchip
31 actuator
ported head
magnex s/s exhaust
lowered 25mm
ford puma gearnob
Register on www.photobucket.com or simply click the uploader at the top left of this page. Once there you can upload your pics to your photobucket account and then copy the bottom of the three links to your post on PF and the pics will appear
ur need bigger injetors to see u past 220 and u can run no more then one bar becasue ur on ofac change to ofab
change ur chip and go for a live map and get a kent 35 in there and get a .63houseing and bigger injetors and ur see 250
JK12
33
Apr 26, 2021 12:09 PM
