Brakes
Old Oct 14, 2005 | 01:06 PM
JamesS2RS's Avatar
JamesS2RS
Default Brakes
What would you recommend for a good brake setup? I have already brought the Zoo motor sport rear brake conversion. What should I do for the front???
Old Oct 14, 2005 | 01:37 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
S2 calipers and 2wd cossie discs with the spacer bracket for the caliper!
If you want better, St170 set up, and next up would be focus RS brembos and discs, and then your into AP water cooled 6 pots
Old Oct 14, 2005 | 01:40 PM
JamesS2RS's Avatar
JamesS2RS
Where Would i get the spacer bracket from?
Old Oct 14, 2005 | 02:40 PM
adamS2RST's Avatar
adamS2RST
I have the same rear kit as you, and 300mm ST170 fronts, they are excellent brakes for the money!
Old Oct 14, 2005 | 02:55 PM
JamesS2RS's Avatar
JamesS2RS
Adam where do you get the fixing kit for the front brakes??
Old Oct 14, 2005 | 03:11 PM
adamS2RST's Avatar
adamS2RST
I got calipers, pads, bolts, washers, discs all in the kit mate (bought privately) You could try sending a pm to xfactor - he used to sell these kits.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
