cossy parts clearout UPDATED
All ex- works team or Mountune
Pectel T6 ECU £ 1450
.63 turbo housing £ 150
8 injector RS500 plenum £ 1400
WRC 8 injector plenum and rail £ 398 SOLD BUT I HAVE MORE COMING
GPA Square rear beam £ 400
Steel front GPA cross member £ 400
GPA trubo with 247 £ 1650
WRC turbo complete £ 1850 ONE SOLD THREE LEFT
Quaife thick wall front diff £ 750
Pectel works spec monitors £ 450 ALL SOLD
2 WD big wing sump £ 280
2WD quick rack £ 500
Pectel T3 ECU £ 700
Quaife 5 speed dog box £ 3500
WRC alloy TCA £ 250
WRC side exit exhaust £ 500
GPA lightened fly wheel £ 150
AP 355mm brake kit £ 850 ALL TEN SETS ARE NOW SOLD
WRC water radiator £ 450
Tarmac proflex damper set £ 1200
Mag pedal box £ 450
MS 90 rear prop shaft £ 350
MS91 rear prop shaft with hand brake £ 350
MS 90 front prop £ 250
Pectel T3 ECU £ 700
WRC alloy TCA £ 250
Mag pedal box £ 450
