Anyone running a std cam?
Oct 12, 2005 | 03:32 PM
heard these are still pretty good from a tuner.??? for a punchy car
Oct 12, 2005 | 04:30 PM
yeah they are susposed to good, TBH i switched back to my std cam for a while, and car seemed quicker mid range.
Oct 12, 2005 | 04:34 PM
Intresting
im gonna get rid of my piper t2 soon as its all high up power..so gonna try this
Oct 12, 2005 | 04:38 PM
if u wanna sell that piper pm me mate, i need high end power at the mo, my cam seems to die early
Oct 12, 2005 | 04:42 PM
Cams sold to my m8 sorry 2 months old too
Oct 12, 2005 | 05:31 PM
Oct 12, 2005 | 05:36 PM
Well il be changing my turbo unit too to a stage 2 55trim 36 exhaust .
I have a cossie stage 3 on now and its just too big
Oct 12, 2005 | 08:51 PM
got a new std cam sitting here at moment got to get round to fitting is as got kent cvh35 cam in at moment but one off loabs is badly worn.
Oct 12, 2005 | 10:41 PM
rs_daz
I'd keep the T2 in then. When u say cossie stg3, what spec is it? If it's got cut back exhasust wheel, or a 0.63 housing it's bad news...[/quote]
Oct 13, 2005 | 12:48 AM
its a saff stage 3 60 trim wheel (says A/R 42 ???)
and 48 exhaust hsing..
im after a punchy car not all high end like it is now..
Plan was std cam
stage 2 turbo 55trim and std exhaust hsing 36?
Oct 13, 2005 | 01:44 AM
im using a kent cam
sad i know, but i am going to be using a standard cam asap
Oct 13, 2005 | 01:03 PM
I once heard this but with a vernier set up, its interesting.
Oct 13, 2005 | 02:45 PM
I got a vernier so i will find out soon
STD cam from ford is about Ł130 i can get one for Ł100 with discount etc
so gonna give this a go..
Oct 13, 2005 | 03:26 PM
Oct 13, 2005 | 03:29 PM
The cam and anti pump lifters are about 1 month old? sud be ok to still use the lifters? there about 350 miles old
Oct 13, 2005 | 06:55 PM
nope - u HAVE to use new lifters, they are bedded into the cam - it'll wear out in noi time otherwise.
Oct 13, 2005 | 08:02 PM
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
Oct 13, 2005 | 10:00 PM
cam in my all singing cvh costs 75 quid complete with follwers from motor factors...
Oct 14, 2005 | 02:13 AM
Oct 14, 2005 | 02:10 PM
A tuner once told me that the std cam is not bad at all.
High duration ones have the risk of the mixture being "blown through"
partly by the boost pressure.
Also the biggest torque of the engine is not in the high rev area.
Oct 15, 2005 | 05:57 PM
In my opinion, wild cams work well with high boost. When using relatively low boost like 1bar, the standard cam gives good power and a very nice power band. Starts to pull strongly right from 2500rpm.
Oct 15, 2005 | 06:52 PM
The best spec on a cvh, using the traditonal turbos, is a wild cam on a stage 2 turbo - they go like hell. My engine is pretty diff, and a 0.48 cos turbo works well, but i can rev it. t34 going on soon, as i have on here - but really want to play with the bigger gt28's
[/quote]
Oct 17, 2005 | 06:46 AM
JesseT, I fully agree.
I love the looks of the Orion and of course the S1,
but I do not agree with the S2 wheels on your S1
Oct 17, 2005 | 07:12 AM
Standard cam is rubbish at high rpms, no need to take it much beyond 5000 rpm, is a steep downhill from there.
Oct 17, 2005 | 07:21 AM
It's an old picture of when it was built, but not yet fully finished. Those were the wheels that were on it to able pushing it around the garage. You might notice some minor parts missing too. It's on seven spokes now as it should. I should update the pictures, but my digital camera went bust some time ago and I haven't bought a new one yet.
Oct 18, 2005 | 04:40 PM
Well ordered up my std cam today as my piper cam failed..had oil pissing out the pulley end bolt hole..not impressed so some seal has messed up inside the cam..so il be sending that bk to em
Oct 18, 2005 | 05:05 PM
Standard cam in the Fes and use a KEnt CVH35 in my S2. No complaints at the mo from me. Tempted to try a Newman cam in the Fes when I get that far with it
Oct 18, 2005 | 08:08 PM
Yeh i heard newman cams are good but abit pricy and you can only run them with there solid lifters etc
Im going for std one as advised by karl norris
Oct 18, 2005 | 09:02 PM
Oct 18, 2005 | 09:25 PM
How easy are thos solid lifter to adjust?
Oct 18, 2005 | 09:38 PM
i find them quite easy but thats maybe because i have fitted three of these cams to different cars which were the off the shelf turbo cam, they have just brought out a new profile. for the rs turbo. my custom cam is a bit my radical then the cvh37... i had major problems with kent cams they use shite blanks,
its a toss up wheather there cams last 200- or 10000 miles
Oct 21, 2005 | 05:05 PM
Well fitted my std cam today and it has made the car alot better..
Its alot smoother and revs right up to 6.5k which it didnt before..
Oct 22, 2005 | 10:00 AM
what did it rev too before ? mine pulls pretty hard now and revs to 6.5k but that was on standard turbo ,and i think the head was just port matched will find out when it comes off
Oct 22, 2005 | 10:51 AM
Ive heard that the standard cam is the same as in the CVH XR3i. Can any one confirm this?
Oct 22, 2005 | 05:02 PM
Only reved to 5.7k then ran on 3cycl sod knows why..
Ok now right up to 6.5k
Oct 22, 2005 | 07:46 PM
Yes it is.
Oct 23, 2005 | 04:57 PM
Quote:
Originally Posted by Rick
Yes it is.
Same cam, but a different cam pulley to retard it a bit compared to XR3i.
Oct 23, 2005 | 05:55 PM
my cam is the origional and the car has done 109000. does this mean i need a new cam.
Oct 23, 2005 | 07:58 PM
KA pulley on the RST, can't remeber what the other one is. I ran this one on a cvh 35 and it worked really well lol.
Oct 23, 2005 | 08:01 PM
You will find ur cam is very worn, and a new one will make the car a lot more punchy
