ive got a 10 in line oil cooler rad ive got a good place to fit it i think. if i take a part of the shroud off that goes round the blower mechanism it will fit nicely on its side under that bonnet vent with the ends of the cooler resting on plastic cover and the strut brace
what ya reckon you rs gang
i forgot to tell you all that it is a 1.9 zvh accrilte race pistons,farndon rods hardened crank shaft,the dogs cylinder head,cossie managment etc,etc so i think it needs cooling down a bit
