Over heating
Old Oct 10, 2005 | 11:09 PM
SamERST's Avatar
SamERST
Default Over heating
What can it be these last two days my s2 rs has sat at max when driving around town but it will sit at half unless booting it down the motorway ???!!! Head gasket ?
also when i come to a stop the water hoses are fooking boiling and i can hear a strange sisssing noise but nothing comes from anywhere ???
Old Oct 10, 2005 | 11:23 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
that takes me back to my old RST, there will defo be a hole sumwhere on the hoses with that hissing and it'l be in the most fookin annoyin place possible (always is)....
have you got two fans running constant? as much as most people hate them when i fitted bonnet raisers to me old 1 airflow was seriously improved and i did notice a difference. worth a try maybe??
long shot but you might have an airlock....
Old Oct 10, 2005 | 11:51 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Maybe a hole in the Header Tank? Is it a Ford one?
Old Oct 11, 2005 | 06:13 AM
adamS2RST's Avatar
adamS2RST
Could be a number of things....
IS the car standard? or do you run a fmic? Fan(s) are working as they should I assume - more info needed please
Old Oct 11, 2005 | 11:29 AM
SamERST's Avatar
SamERST
Hi guys its running a 4x4 saff cossie, stage 3 head, camed etc loads of other bits buuuuuuuuuuuut... a standard ic Ive only got a standard fan on the rad which ive put on a switch. The car has never done this before till it over heated once a couple of weeks ago and burst a water hose which i replaced so i think it may be an air lock. How would i go about sorting it out ?
btw ad4m rst i saw your car last night mate its fucking amazing !!! I was the white s2 with polished roll cage parked infront to the left of you.
Sam
Old Oct 11, 2005 | 05:35 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
running a 4x4 saff cossie what?
Get a bigger IC, why oh why do you still run a standard one with a stg3 head, cam etc? what boost do you run? anything over 16psi on a standard engine is asking for trouble so think what it will be like with the mods you have!!
check easy things first off, fans kicking and switching off as normal? thermostat working fine? header tank cap sealing properly (maybe hissing noise!!) if you think you have an airlock, take the small hose off the top of the thermostat housing and run till a sollid flow of water comes out once warmed up (that's how i bleed mine and works for me)
also flush out the rad, may help a little!
Old Oct 14, 2005 | 07:32 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
have you a hissing dv?
Old Oct 15, 2005 | 11:16 PM
akito-man's Avatar
akito-man
or maybe your brake servo pressuring up?
Old Oct 16, 2005 | 12:20 PM
Moonie's Avatar
Moonie
Mite be worth looking at the expansion tank cap, if its not holding pressure it wil allow the water to boil, this maybe where you hissing noise is coming from?
Old Oct 16, 2005 | 12:26 PM
akito-man's Avatar
akito-man
or a snake!
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
cossie09
Sep 10, 2015 06:56 PM
