General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
just been informed of the final rwyb of the year at elvington from straightliners, usual £45 per car for unlimited 1/4m and top speed runs. will run regardless of weather, final chance for a play before putting the cars to bed for the winter!
signing on from 9am as usual, helmets are required.
rgds
they do run bracket classes, ie 14.5s, 13.5s 12.5s etc etc, so you will end up running against similar speed cars in your class. each class has a shoot out final at the end of the day normally.
and yes its @ elvington airfield, not Melbourne (York Dragway)
there is a bike rwyb on the 23rd at elvington for the bikers
Ive been told to use him, hes not far from cineworld is he? does he check fueling, boost pressure, ignition timing and (cam timing if aplicable) on a normal setup?
