How low should a low comp engine be?
Old Oct 10, 2005 | 06:57 PM
BlackRs's Avatar
BlackRs
Default How low should a low comp engine be?
Did a compression test on my s2 and all four cylinders showed 90. A standard s2 should be all roughly 150 im told. Is this correct?
Old Oct 10, 2005 | 08:54 PM
turbo.jon's Avatar
turbo.jon
My engine im using at moment is low comp and that was 125psi on all 4 when i tested it which is 9 bar roughly what is your psi or bar??
Old Oct 10, 2005 | 08:57 PM
BlackRs's Avatar
BlackRs
doesnt sound too good then my engine. Will have to wait and see. Cheers for the help
Old Oct 11, 2005 | 12:18 PM
Badman38's Avatar
Badman38
Default Re: How low should a low comp engine be?
90psi i would say rebuild mate thats way too low
Old Oct 11, 2005 | 12:37 PM
BlackRs's Avatar
BlackRs
My engine was rebuilt not long ago. Boosts fine sounds sweet aswell. No rattles or anything tappety. But was thinking it was a little low.
Old Oct 11, 2005 | 12:58 PM
Badman38's Avatar
Badman38
when you conducted the compression test did you open the throttle is the gauge working properly because something amiss
Old Oct 11, 2005 | 02:16 PM
ivorbiggun's Avatar
ivorbiggun
Have you measured that correctly cos strictly speaking it shouldn't run. And do you have anything to compare it to cos off boost it must be bloody awful.
Old Oct 11, 2005 | 03:13 PM
BlackRs's Avatar
BlackRs
well thats the problem. Replaced the thermostat, leads and did a complete engine coolant flush. Started the car up and it sat running for a good half an hour. Drove up the road and it just cut out. No spluttering, no bang just cut out. Since then the car hasnt started. Did a compression test and showed the above results. But what im stuck on is that the engine ran, drove & started spot on without any noise at all. Also if the engine was fcked wouldnt the compression be uneven??
Ive also tried a differant ecu,dizzy,rotary arm & plugs. Oh and its gone fuel. Aswell as spark and the pump is priming.
Old Oct 11, 2005 | 03:43 PM
S1 JOHN's Avatar
S1 JOHN
mine is low comp if i remember rightly it was 125 on all four so 90 is quite low is the guage accurate can you lay your hands on another one?
Old Oct 11, 2005 | 03:55 PM
BlackRs's Avatar
BlackRs
Will try another one as a rebuild is not wanted i really wanted to hear at the moment but it seems that, that is the way its going.
Old Oct 11, 2005 | 04:17 PM
Badman38's Avatar
Badman38
mine was down to 100psi on number one cylinder and the car missed like mad below 2000rpm 90psi something badly gone wrong
Old Oct 11, 2005 | 04:42 PM
Oranoco's Avatar
Oranoco
I'm sure mine is 90 across all four and it still goes like buggery and doesn't use a drop of oil or smoke at all
Old Oct 11, 2005 | 05:40 PM
Badman38's Avatar
Badman38
you sure m8 90psi car would have trouble starting thats if it would start at all
Old Oct 11, 2005 | 05:47 PM
Oranoco's Avatar
Oranoco
I might be wrong then but I'm pretty sure that's what it was
Old Oct 31, 2005 | 04:15 PM
ivorbiggun's Avatar
ivorbiggun
OK Kiddies, lets remember we're all playing silly buggers with cars and components that are the best part of 20 years old. When doing things like
flushing engines, corrosion is quite likely to to rear it's ugly head...
even if it has had had anti freeze at the correct levels for those 2 decades
it's not inconceivable that some of that alloy head has called it a day
and just let go. Not sure why one would decide to flush an engine but as me old Grandad used to say.......if ain't broke don't try to fix it.
Old Nov 2, 2005 | 02:31 PM
ASHCOSSIE's Avatar
ASHCOSSIE
i once had an engine in my rs the bores went oval and that had very low comp on all cylinders and i was told that below 90psi the car would not start and it dident so i scraped the lump i hope thats not your case as u said it was rebuilt a while back
does anyone know what causes an engins bores to go oval?is it high milage or some thing along them lines?
Old Nov 2, 2005 | 04:02 PM
addiction's Avatar
addiction
should be 150 across the 4 cylinders
Old Nov 2, 2005 | 04:06 PM
andre_k's Avatar
andre_k
scrap the low comp, and bang a standard engine in... all will be ok.
Old Nov 2, 2005 | 08:04 PM
Big-J's Avatar
Big-J
Steer fi the rear!
mine is 120 mate running low comp pistons
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Ben26
Aug 27, 2015 08:56 PM
ekjim
Aug 17, 2015 08:57 PM
MadsBL
Wheels and Tyres
Aug 6, 2015 10:04 AM
