pectel monitor owners with P8 management..... read on
Old Oct 10, 2005 | 05:06 PM
DaveEscos's Avatar
DaveEscos
Default pectel monitor owners with P8 management..... read on
does the ECU need modding / programming to talk to the monitor?
or should it just be plug and play ?
im getting a no communication to ECU message on the monitor
Old Oct 10, 2005 | 05:10 PM
gus's Avatar
gus
the one i borrowed was plug and play
Old Oct 10, 2005 | 05:14 PM
The DIVA's Avatar
The DIVA
If it`s a genuine Pectel monitor i presume it will need pectel software in the ecu....
Old Oct 10, 2005 | 05:15 PM
Eagle Systems's Avatar
Eagle Systems
the ecu on my escort cossie needed modding as it has P8 managment
Old Oct 10, 2005 | 05:17 PM
jon@work's Avatar
jon@work
My P8 (without Pectel board) needed something "switched on" on the chip whilst being mapped to work my monitor.
Old Oct 10, 2005 | 05:18 PM
gus's Avatar
gus
may be mine had what it needed then
Old Oct 10, 2005 | 05:19 PM
DaveEscos's Avatar
DaveEscos
aah.. this could be my problem. Yes im using P8 aswell
any idea if the switch in the ECU is a 'manual' one or a software one?
Old Oct 10, 2005 | 05:20 PM
Eagle Systems
mine had a pectel board already and needed extra wiring done inside the p8 box to make it work.
dont know what it was as grove did it all (ahmed blowjob)
Old Oct 10, 2005 | 05:23 PM
jon@work's Avatar
jon@work
software switch required, I believe
Old Oct 10, 2005 | 05:25 PM
DaveEscos's Avatar
DaveEscos
cool, ill give ahmed/harvey a call tomorrow
Old Oct 10, 2005 | 06:23 PM
GARETH T's Avatar
GARETH T
i had to pay something like 60 quid to have my data stream turned on when i had a p8! it had a pectel/ahmed board fitted
Old Oct 10, 2005 | 06:26 PM
markk's Avatar
markk
needs an internal board mod as well for p8
Old Oct 10, 2005 | 06:29 PM
DaveEscos's Avatar
DaveEscos
right, with the engine running, if i turn it to datalog, then back.. it reads ok.. but cerain features arent on there.. ie water is 0 , fuel time is ) etc..
looks like i need my ecu sorted then
Old Oct 10, 2005 | 06:50 PM
Billabong's Avatar
Billabong
Ahmed/Harvey supplied chips usually have datastream switched on (software) but as Markk points out, the P8 ECU board will need a slight 'hardware' mod, which Harvey can do for you.
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
rsguy
44
Sep 29, 2015 03:29 PM
jay030787
Sep 25, 2015 01:38 AM
