What Grafix card?
I think I need to upgrade my Grafix card,
Curently using an ATI Radeon 9500, Just started using my PC to play games and it needs to run in low settings
My system is a Packard Bell AMD athlon 64, 3200+
Will any grafix card work? And which would you recomend?
I've just bought an XFX 256mb nvidia 7800GTX 490mhz version. It's pretty sweet but not cheap.
http://www.komplett.co.uk/k/ki.asp?sku=311291&cks=PRL
Originally Posted by Rick
Depends on ur budget mate. The 850/7800 are the best, but not really needed. A 6600GT is v good value for money, and light years ahead of what u have.
depends on your budget but i'd go for one of these:-
Ł100 - Nvidia 6600 GT (AGP)
Ł200 - Nvidia 6800 GT (AGP)
Ł250 - Nvidia 7800 GT (PCI-E)
I use the 6600GT and it plays BF2 at 1024x768 at max settings just fine.
Originally Posted by Dean Saff
Does it matter what make, Ive seen Galaxy,nVIDIA,Novatech, club etc.
Which one do I go for?
What the difference between AGP and PCI-E. And how do I find out which one I need. Seen lots of these card on ebay etc but they always state "make sure it will fit your mobo"?
You need to post up your Mobo spec, Processor and present memory mate
Like asking for an engine when we dont know what its going into!
The least troublesome cards and drivers at the mid/higher end seem to be Radeon. But its a waste of time bragging about your high spec card when its in a 5 year old Jetway MOBO with 256 of PC100 memory. lol
If you use a GeForce .. and you dont want problems ,, stick to the Windows Certified drivers, too. Same goes for ATI, but their drivers seem to be better engineered anyways.
For the record, I am using an ATI 9600 Pro and in my Speed box .. an ATI Radeon X800XT Platinum (one of the best cards money can buy)
[quote="Al Bags"]You need to post up your Mobo spec, Processor and present memory mate [quote]
It has 2.20 Ghz, 1.00 GB of RAM. How do I find out my mobo details
Just spoke to PC World
They said any card would fit AGP, PCI etc said PCI-E is the fastest?
Sorry .. Just seen this ..
That 9600 Pro is well below what your Motherboard can probably support .. We still need to know what Mobo.
It will be AGP or PCI Express (forget the other PCI ones ; )
You should be looking at 128 ATI or similar.
Download this system info app .. Run it .. then post the results for the Mobo name .. memory, Graphics slot info, processor. Theres loads of info produced!
http://www.majorgeeks.com/download181.html
Your mobo MAY support dual-channel memory .. If it does .. you would prob have two matching sticks of memory. If it only has one stick (but supports two) there may be a performance upgrade available there .. even if you do have 1Gb already.
Al.
Al.
Cheers mate, downloaded and run that file,
Motherboard Properties
Motherboard ID 07/27/2004-K8T800-8237-6A7L0G09C-00
Motherboard Name Unknown
Front Side Bus Properties
Bus Type AMD Hammer
Real Clock 200 MHz
Effective Clock 200 MHz
Memory Bus Properties
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 200 MHz (DDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
I'm not a big pc gamer, just like the games look and play good.
Would I be better off going for a card with 128 or 256 MB's
Bus Type AMD Hammer
Real Clock 200 MHz
Bus Type DDR SDRAM
Bus Width 64-bit
Bandwidth 3200 MB/s
Unknown .. .lol : (
128 or 256 will not be much noticeable difference for you.
Still need to look at mobo or get info about the slot type and model : (
Get any manual with the PC?
Originally Posted by Al Bags
Look for the Name on the Mobo somewhere .. may be between the PCI slots .. in coloured paint!
Watch the place fill with dust ; )
Cant see a name, but it has two sticks of RAM, a brown connector for the grafix card, not sure what eles you need so heres a picture
I cant ID it mate from that pic .. been looking ..
Looks like 1x AGP, 3x PCI, Via chipset .. I recognise, but cant remember that gold chip heatsink .. maybe MSI.
There will be info on it somewhere.
I'll show the pic to a mate tomoz .. he builds a few, too ; )
Whats that in the bottom slot position?
