Will a T34 off a 2wd fit my 4x4?
Old Oct 10, 2005 | 12:04 PM
churchy's Avatar
churchy
From: Out Shooting Burgelers, cause thats what Norfolk people do!!!
Default Will a T34 off a 2wd fit my 4x4?
Right, I've been offered a good cond T34 with a .63 exhause housing for a very good price, trouble is it's off a RWD cossie, whereas mine is a 4x4. So 1. would it go on, 2. if not, what would be involved with making it fit?
I thank u in advance for your help
Old Oct 10, 2005 | 12:11 PM
kevmk2's Avatar
kevmk2
Usually you have to turn the compressor housing around a fit a bracket for the actuator to fit
Not sure where you get the adaptor bracket from i would say maybe A1's or somewhere like that
Old Oct 10, 2005 | 12:14 PM
churchy's Avatar
churchy
Cheers Kev
Can someone expand on that, mr Rainbird maybe, or Stu?
Idear of cost would be nice too, to see if its worth it, but I'm guessin it will be. Would swapping my exhause manifold for a 2wd one work?
Old Oct 10, 2005 | 12:15 PM
Graceland's Avatar
Graceland
Team HOTHOT!
to make it fit your car mike, you'll need to take the turbine housing and compressor cover off and then rotate them and put it back together - there are little dots cast into the turbine housing and comp cover, these dots are to be lined up together with the oil feed pipe been bang in the middle of them - that way all the orientation is correct for 4x4 fitment
also, if the compressor cover has had its cast actuator bracket cut off, you will need to use one off a 2wd turbo (should come with one on it if its off a 2wd car) and affix this in the correct place to make it all good
Old Oct 10, 2005 | 12:20 PM
churchy's Avatar
churchy
Cheers Paul
Don't suppose anyone has an Idear how much it would cost to do? If the price is right I'll send it to ya to get done
Old Oct 10, 2005 | 12:31 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
a 2wd actuator bracket will not fit the compressor housing radius, the exhaust turbine housing may have been threaded and helicoiled these will need to be removed to fit the 4x4 manifold
Old Oct 10, 2005 | 12:33 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Tony - i know it won't, but it can be made to fit
Mike - won't cost fackall - apart from 20 mins of your time
Old Oct 10, 2005 | 12:36 PM
churchy's Avatar
churchy
I do have the use of a cnc mill, so if there is any holes or bits that need to be machined, it can be done, as long as i can hold it
Basically, I suppose the ultimate question is, is it worth it? It sounds ok though Cheers lad
Old Oct 10, 2005 | 01:11 PM
churchy's Avatar
churchy
Old Oct 10, 2005 | 01:22 PM
CraigN's Avatar
CraigN
as tony said the studs come out of the manifold on a 4x4 and out of the turbo on a 2wd
Old Oct 10, 2005 | 01:28 PM
churchy's Avatar
churchy
Does anyone have any pics so I can get an idear? Pretty please
Old Oct 10, 2005 | 01:41 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Mike,
Which bit don't you understand?
The above explanations are totally clear and concise to me ?
This is what you are trying to achieve .
From this:
to this:
Note change in position of actuator....
Old Oct 10, 2005 | 01:49 PM
RichardPON's Avatar
RichardPON
Right.................
On my 4x4 manifold, using the actuator mount built into the compressor housing.
On the old 2wd manifold, using a custom bracket, and with the compressor spun through 90 degrees.
Old Oct 10, 2005 | 02:03 PM
churchy's Avatar
churchy
Nice one, cheers lads, it all makes sense now, much appreciated
Mike, you know what I'm like
jason_nike
Aug 18, 2019 10:53 AM
mrmann
Aug 20, 2015 11:24 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
