Flickering brake light on dash / s2
Old Oct 9, 2005 | 06:26 PM
Stu.H's Avatar
Stu.H
Default Flickering brake light on dash / s2
Is this the switch that attaches to the handbrake? I know they are prone to get a bit faulty...
Just cacks me up a bit when Im belting it and it flickers coz I think its the oil light
How to rectify please people, and what parts I need.
Old Oct 9, 2005 | 06:29 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
brake fluid warning light too often caused when the fluid is a bit low
Old Oct 9, 2005 | 06:32 PM
KSA-Cossie's Avatar
KSA-Cossie
Or a faulty sender unit or plug.
Old Oct 9, 2005 | 06:40 PM
Stu.H's Avatar
Stu.H
where is it located?
Old Oct 9, 2005 | 06:46 PM
KSA-Cossie's Avatar
KSA-Cossie
In the engine bay,it's the thing that sits in your brake fluid m8.
Old Oct 9, 2005 | 06:53 PM
Stu.H's Avatar
Stu.H
gotcha
ok i will point out, when the hand brake is put on, both the brake light and the abs light comes on, if JUST the brake light is coming on, does this point to the sensor? or COULD it be that switch by hand brake?
thanks for help!
Old Oct 9, 2005 | 06:56 PM
KSA-Cossie's Avatar
KSA-Cossie
Deffo the sensor in the end i changed mine to one off a mk3 fiesta.
Old Oct 9, 2005 | 06:59 PM
Stu.H's Avatar
Stu.H
ok cool, will try and nick me mates off his s1 (hi tony)
i spose if its a faulty switch by the handbrake, both would flicker on!
cheers for ya help mate
Old Oct 9, 2005 | 07:18 PM
Sean_RS's Avatar
Sean_RS
Both lights have just started to flicker on my frst... lookin at these replies i may wanna check the switch i take it...
Old Oct 9, 2005 | 07:27 PM
Stu.H's Avatar
Stu.H
if both flicker, it sounds like it will be the switch that connects to handbrake.
could be wrong tho m8
Old Oct 9, 2005 | 07:30 PM
Sean_RS's Avatar
Sean_RS
Cheers m8 ill look in to it
Old Oct 9, 2005 | 07:32 PM
KSA-Cossie's Avatar
KSA-Cossie
If you have a haynes manual check the wiring m8.
yatta
May 21, 2016 10:31 PM
fuzzy
Sep 4, 2015 10:11 PM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
turbowag
Sep 3, 2015 08:07 AM
