quick rs turbo spring question
i need rs turbo -60mm lowering srings for the rear of my escort mk4.
all i can find is -40mm.
there are loads of -60mm springs but they are not 60mm lower than the rs turbo height they are just 40mm lower.
can anyone tell me where i can get some 60's from please.
just the rears needed but i suppose i'll have to buy the whole kit.
Originally Posted by James Raby
Pi springs
my car is totally stripped out and is very light at the back, this has raised the car up 20mm, i want the car lowered back down again so i need 60mm lowering springs for the rs turbo.
i havnt even got a spoiler at the back so its light as fook.
if you have sounds in your car then your car will sit low
Pi did used to do 60mm. To be honest, every S2 sits differently. Mine is on -25mm and its very very low, i want to raise it to be honest. The mounts seem to have different tolerances.
i got a pair of custom rear springs made from www.coilsprings.co.uk for one of my motors. cost about 90 bucks i'm sure.
Matt Baxter
Sep 16, 2015 08:30 PM
borboyous
Aug 22, 2015 11:17 AM
