boost drop
Old Oct 8, 2005 | 08:04 PM
kiddie's Avatar
kiddie
Default boost drop
Hey people, my car peaks at 25psi but then drops off to anywhere between 20-23 psi. It won't hold 25psi, would a boost controller cure this?
Old Oct 8, 2005 | 08:07 PM
James Raby's Avatar
James Raby
Yus it would
As expl;ained earlier, sure Chistian can get you one at a reasonable price - ring APT on Monday
Old Oct 8, 2005 | 08:16 PM
kiddie's Avatar
kiddie
Yeh I need to but can't really afford one atm, what I need is some1 with a second hand one willing to make a deal.............
Old Oct 9, 2005 | 03:25 PM
kiddie's Avatar
kiddie
Is a boost controller the only thing thing I can try?
Old Oct 9, 2005 | 10:32 PM
GrimmeRS2K's Avatar
GrimmeRS2K
there is a trick i heard the other day off somebody on here, about a small vacuum pipe connected to the charge carrier which can hold boost.
Old Oct 10, 2005 | 11:43 AM
Rick's Avatar
Rick
It all depends. At what rpm does it drop off at? It maybe the turbo is simply running out of puff. 25psi to 23psi is hardly a problem anyway, u probably won't gain any more power.
Old Oct 10, 2005 | 12:18 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Me
It's not fool proof, but it helps, alot.
Old Oct 10, 2005 | 07:01 PM
kiddie's Avatar
kiddie
As soon as it comes on boost its up to 25psi then down to 20-23ish then back up as the revs climb?? Tony whats the mod matey?
Old Oct 10, 2005 | 09:39 PM
Rick's Avatar
Rick
The mod is taking the actuator feed from the crossover pipe instead of the compressor housing.
Old Oct 10, 2005 | 11:50 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Maybe its just a weak Actuator? Is it a -31? Might be worth trying a -34.
Old Oct 11, 2005 | 05:34 PM
kiddie's Avatar
kiddie
Ok mate, will do actually you can when you next have it
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Marv888
Sep 26, 2015 03:44 PM
Russ Payne
Sep 25, 2015 08:29 PM
