what's the difference between 4wd and 2wd cossy heads???
Old Oct 8, 2005 | 03:32 PM
cosworthbg's Avatar
cosworthbg
Default what's the difference between 4wd and 2wd cossy heads???
Old Oct 8, 2005 | 03:37 PM
Ginge !'s Avatar
Ginge !
just finding my feet
the head chamber i belive is higher CR on the 4x4 , not totally sure though and the 2wd head has turbo dampner mounts
also the oil feed is from the head and not the block on a 4x4 head/engine
might be others too
Old Oct 8, 2005 | 03:40 PM
Ryan's Avatar
Ryan
Turbo Oil Feed Is in a different position, WTS sensor is a difference position.
As Ginge said, no turbo mounts on a 4x4 head.
Old Oct 8, 2005 | 03:43 PM
Ginge !'s Avatar
Ginge !
ryan what about the CR compared to the 2wd or is that the block
Old Oct 8, 2005 | 03:50 PM
Ryan's Avatar
Ryan
not a clue to be honest, but i seem to remember it being the pistons not the combustion chamber, could be completely wrong though
Old Oct 8, 2005 | 04:00 PM
Niall.b's Avatar
Niall.b
2 bolt holes for thermostat housing on 2wd, 4x4 has 3. head stud washers are larger on 4x4 too
Old Oct 8, 2005 | 04:10 PM
jon@work's Avatar
jon@work
that only applies to the early 2wd heads - later ones had large washers and 3 bolt thermostat fixings
Old Oct 8, 2005 | 04:14 PM
mk5cos's Avatar
mk5cos
better cooling as well... so i read! small turbo has better valve guides.
Old Oct 8, 2005 | 04:19 PM
Niall.b's Avatar
Niall.b
true, was thinking primarily about my 3 door and the 4x4 & forgetting 2wd saff.
having a blonde day
Oct 9, 2015 07:38 PM
turbotrev
Aug 22, 2015 11:41 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
shortie
Aug 19, 2015 01:01 AM
lockie
Jul 31, 2015 10:03 PM
