Group A coil
Old Oct 7, 2005 | 11:15 AM
bigbobby's Avatar
bigbobby
Default Group A coil
what improvments will it have over a standard one for car in sig.
gaz
Old Oct 7, 2005 | 12:16 PM
Stealth Bomber's Avatar
Stealth Bomber
Kinda interested too.
Old Oct 7, 2005 | 01:42 PM
carlo's Avatar
carlo
Come on guys help this man out??
Old Oct 7, 2005 | 01:51 PM
Micky's Avatar
Micky
None,regards Micky
Old Oct 7, 2005 | 02:00 PM
Franco's Avatar
Franco
it lets you run a bigger spark!
Old Oct 7, 2005 | 02:41 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Providing your ignition system is all up to scratch, then you can run a larger plug gap, which give a better combustion, and this may see an improvement in both economy and power. However, on a 130bhp car, don't expect to feel much other than a bit of a "cleaner" response. Completely pointless if your leads / plugs / dizzy is 50 years old and done a 1,000,000 miles .
Old Oct 7, 2005 | 02:46 PM
bigbobby's Avatar
bigbobby
Mike just read fast ford why did they put it on a ka, it came from you. my car runs a stage 3 engine with 230bhp will it make a difference?
Gaz
Old Oct 7, 2005 | 02:48 PM
Mike Rainbird
Caraholic
I have no idea, I thought it was going on Nick's Escort . As I said it allows you to do the above, so providing that the rest of your car's ignition system is up to scratch then it is beneficial. The extent of how this is measured is only a couple of bhp and mpg, but it is just a belt and braces job that the ignition is as good as you can get it. The stronger spark is less prone to boost blow-out though, so is highly recommended on a car running big psi .
Old Oct 7, 2005 | 02:52 PM
bigbobby's Avatar
bigbobby
what a horrible car they should of bought 40quids worth of spray tins and painted it a different colour
Old Oct 7, 2005 | 03:03 PM
bigbobby's Avatar
bigbobby
come on then is it worth buying one.
Old Oct 7, 2005 | 03:19 PM
Mike Rainbird
Caraholic
If you're having spark plug blow-out issues and a fluffy high rpm feel, than yes. If not, then leave alone.
Old Oct 7, 2005 | 03:23 PM
Franco's Avatar
Franco
Well i thought it was being fitted to Nicks...............Check the feature again.
PS why would they put it on a dissyless car, they cant'
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
beller
Sep 21, 2015 04:13 AM
