block paint
Old Oct 6, 2005 | 10:55 PM
turbo orion's Avatar
turbo orion
Default block paint
can any 1 recomend a decent paint to use on a block that doesn't flake & peel off when it gets hot.
Old Oct 6, 2005 | 11:13 PM
I use radiator paint normally, which DOES flake off but only if it gets hotter than your block should be anyway.
Old Oct 6, 2005 | 11:14 PM
PS
reason is that way if an engine goes wrong and someone says it hasnt overheated, you know if it has.
The key is in the preperation though, must be spotlessly clean before you put it on.
Old Oct 8, 2005 | 04:57 PM
turbo orion
nic 1 m8. just building a engine 4 mine want it to look the dog's nuts.
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
rsguy
44
Sep 29, 2015 03:29 PM
20/20 vision
Sep 29, 2015 11:27 AM
