Picture Request
Old Oct 6, 2005 | 03:53 PM
haz87's Avatar
haz87
Default Picture Request
Has anyone got a picture of the window motor(electric) in a mk4 escort 3 door? But i need a picture of it actually fitted. i cant work out how to fit a 3 door motor for sh*t yet the 5 door is easy
Old Oct 6, 2005 | 05:31 PM
haz87's Avatar
haz87
boing
Old Oct 6, 2005 | 05:36 PM
Al Bags's Avatar
Al Bags
You talking about fitting just the bare motor (I have a couple tucked away) or the
assembly complete on the gearbox/rack?
Old Oct 6, 2005 | 05:44 PM
haz87's Avatar
haz87
Complete assembly
Old Oct 6, 2005 | 05:58 PM
Al Bags's Avatar
Al Bags
What bit you stuck with?
The motor sits outside the door, remember, and if your'e changing from manual, you need to drill the rivets out on the old rack, and rivet/bolt in the new one, yes?
Should fit easy then.
Old Oct 6, 2005 | 06:01 PM
haz87's Avatar
haz87
Yup i know the motor sits outside the door and ive drilled/removed the entire winder assembly out.
The 5 door (leccy) assembly goes in fine, motor sitting central(ish) of the door and all the screw holes line up perfectly etc.
However ive got some 3 door ones to fit(as its a 3 door and the 5 doors werent raising/lowering the window properly) and obviously there alot bigger and theres no way in hell the motor sits centrally and i cant seem to find a place on the door where the screw holes line up etc, hence a picture would be useful
Old Oct 6, 2005 | 07:49 PM
Al Bags's Avatar
Al Bags
I think the frame uses different mounting points on the doors when you use the electric rack .. I did mine, but was quite a while back. Sure they arent covered by tape?
Old Oct 6, 2005 | 11:03 PM
haz87's Avatar
haz87
yer i gathered they were in different mounting points, i just cant work out where and theres no tape anywhere
Old Oct 7, 2005 | 12:41 AM
Al Bags's Avatar
Al Bags
Just offer it up .. It should come right and show you where the holes are.
Old Oct 7, 2005 | 11:47 AM
haz87's Avatar
haz87
Ok this is driving me nuts! The five door units fit nicely right in the centre of the door frame but i cant work out where the hell these 3 door ones fit. There straight out an xr3i so i assume they should fit a bog standard 3 door car no problem :mellow: As you can see when the whole units in the full down position, its as long as the bloomin door tho i assume the regulator would stop it getting this far!? Im so damn confused, the internal door (skins?) werent different on different models were they? as said the 5 door units will bolt in fine but there not strong enuf
and i realise im holding the unit the wrong way round(motor should be facing me)
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Mar 5, 2021 06:08 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
