cheers gary!!
Old Oct 6, 2005 | 12:59 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default cheers gary!!
for telling me i need a new engine
honestly going to have a good think i think i might just keep the car and get things done as of when as the rest of the car is mint.
will it damage the engine in any way because of that VVT???
cheers APT for diagnosing the problem
Old Oct 6, 2005 | 01:27 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
whats the crack then? whats up with it? so you did buy a nail?
Old Oct 6, 2005 | 01:42 PM
Roosie's Avatar
Roosie
the VVT is knackerd bottom end is good which i knew cams could do with changing!
apart from that its ok
Old Oct 6, 2005 | 01:51 PM
Spiky's Avatar
Spiky
what the hell is VVT ?????
Old Oct 6, 2005 | 01:52 PM
Roosie's Avatar
Roosie
variable valve timing unit
Old Oct 6, 2005 | 01:53 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Roosie, that wasn't quite the diagnosis now was it??!!
VVT is Fooked
Cams are Fooked
Bottom End doesn't rattle (but that doesn't mean its necessarily good, after all the previous owner just threw a set of shells at it)
Turbo Gaskets are non-existent
Rear Brakes are shot to pieces
Apart from that its as good as a 160,000 mile Automatic S14 gets.
Old Oct 6, 2005 | 01:55 PM
Roosie's Avatar
Roosie
ther not big things tho apart from cams and VVT
im going to keep it but sort it out slowely ie new GOOD Engine to be safe
Old Oct 6, 2005 | 01:56 PM
churchy's Avatar
churchy
From: Out Shooting Burgelers, cause thats what Norfolk people do!!!
At least the tyres are ok
Old Oct 6, 2005 | 03:38 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
There is always the possibility of the bottom end being on its way out though. My bottom end was quiet on my RST, but it still had a bent conrod.
You'll be a crazy fool to replace the cams etc without getting it stripped down and looked at, imo of course.
Old Oct 6, 2005 | 03:43 PM
Christian and Beccy
#1 in Spelling Club
Tony, that opinion is with you being familiar with cams being around £250-£300.
Now imagine if they were more like £600??
To put £600 worth of cams into an engine that could potentially be fooked (i.e. at 160,000 miles the rings could easily be knackered) is like playing Russian Roulette.
Old Oct 6, 2005 | 03:50 PM
Tony Turbo's Avatar
Tony Turbo
So it's a bit like choosing a cam company for an RST then
Cosnada
Sep 2, 2015 01:10 AM
3doorcozmess
Aug 29, 2015 08:14 PM
Tim Wharton
Aug 28, 2015 08:26 PM
RB26DETT
Ford Mondeo Including ST
Aug 28, 2015 01:56 PM
sridgett
18
Aug 1, 2015 08:49 PM
