Automatic cars on rollers...
My brother tried to run his granada cossie on Engine Advantages rollers but couldn't get an accurate reading and was told that you won't ever get a proper reading something to do with the car always changing up.
i put a v8 lexus on the rollers at power engineering and they said the figure will read higher than it actualy was due to the torque converter. the car showed just shy of 300bhp which is about 20 higher than o.e spec.
run it up in top gear....
make sure you can knock it from drive to netural easily thou, its a nightmare if it jumps the rollers and you can wack it in neutral!
Other than that it like any othere car!!
Alex
Alex
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
