Harnesses--How are yours fitted/Bolted in
Just after some advice/pictures please peeps
How are your harnesses fitted, ie the shoulder straps
Where abouts have you put the link rings?
Is there a certain place for saftey where they should go??
Any other info too
Any other info too
LOL
I think there are some bolt holes on the rear of the floor where the bench seat bolted to.
Need to have a look over the weekend....
J
PS I broke the car today- off to Mikes models tomorrow for more fucking spending
J
You should make sure that the rear section of the belt is at no more than a 45deg angle from the horizontal at the point where it leaves the holes in the seat. Any more and you run the risk of breaking your shoulders in a heavy smash. Ideally they should be closer to 90deg. Like Shings suggested, there are mounting points where the rear seats were although i think they are off to one side. You can buy pre-threaded mounting plates from places like Semon-Tweeks that can be welded in the the ideal position.
As above
for the rear belts there is a mandatory maximum limit of -45ş from the horizontal (as John L's pic), If you want to keep your body intact.
The lap belts should idealy angle 65ş rearward.
for the rear belts there is a mandatory maximum limit of -45ş from the horizontal (as John L's pic), If you want to keep your body intact.The lap belts should idealy angle 65ş rearward.
