Hammerite
cool cheers went ahead and done it today put it on real thick so should stay on better, it's pretty good paint smoothes out quite well. looks a lot better than rusty black.
Putting it on thicker wont keep it on better mate - Fallacy
A good prepped surface and blasted/keyed is the best.
Hammerite becomes very hard in service, and will chip off easily.
If you stick it straight on top of layered rust, on a caliper .. Dont expect it to stay there for long!
One thin coat followed by another seems the beast way .. or use primer.
well i took all the rust off, i only used fairy, bit of sand paper and a stiff brush to clean it so i don't expect it to last more than a few years. it didn't need to be keyed since the finish on the calipers and drums is rough as arseholes anyway.
notroubleclubber
Oct 12, 2008 11:11 AM
xr4x4rs
18
Jan 8, 2005 01:10 PM
