Oldskool Hardcore is Back (Mix inside)
If you like your old skool/breakbeats, etc. you might like this new mix by Stu Chapman featuring brand new tunes made in the old skool/breakbeat style (all soon to be released):
1. Darkus - Hardcore Projektz
2. DJ Nee - Feel Good
3. Austin - Can U Feel It
4. Nervous & Anxious - Worlds Collide
5. Amnexiac - Riddim
6. Stu & Nee - The Highest High
7. Vinyl Junkie & D'State - Tour Of Duty
8. The Mouse Crew - Dead On Arrival
9. Vinyl Junkie & Austin - Check It Out
10. Portal - Bad Habits
11. Dead Raver - Guiding Light (Stu Chapman Remix)
12. DJ Fav - Gimme A Break
13. DJ Inferno - Break In
14. Stu Chapman - Dope The Drop
15. Teknotik - Bust A Move
16. Darkus - Shake This Down
17. Sike & Redeye - The Dealer
http://www.hardcore-projektz.com/Mix...utumn_2005.mp3
Enjoy Old Ravers
Enjoy Old Ravers
Nice one Dave
Anyone who was into the Old Scene back in the day i really do reccomend you listen to this mix - It's got everything - Piano Riffs - Vocals - Mad Rave Synth's - Dark Moody Atmosphere - Amen Breaks the lot
good luck with that dave!
I do like that mix but its a bit to mellow for me. I prefer much more "rushy" type breakbeats and hectic pianos.
Its nice to hear people still knocking out the breakbeat hardcore sound though!
I still havn't finished making my tune either!
http://www.djmixtape.net/temp/DJ_Tri...ea_&_Toast.mp3
Most Uplifting?
I'm gagging for a breakbeat 'ardcore mix now!!!
Is there any way of adding tags so I can break it into tracks?
i usually just set 5 min intervals
nero can do what you want (piss easy), or you could piss about creating a cue sheet (bit more fiddly and gives same result really)
cant remember exact sequence but.....in nero drag the file into the compilation window, right click it, properties, set indexes/splits, click new split and click in progress bar of track. you can then edit these to the exact time you want after setting them so you need not be specific when dropping them in to start with (just drop 16 splits and edit afterwards)
get it over to me with the time tracks 2-17 start (post that here) and i'll sort it for you
