CVH Turbo valve stem seals
Old Oct 3, 2005 | 11:31 AM
excursion's Avatar
excursion
Bulletin Board User
Default CVH Turbo valve stem seals
Is it possible to do these witout taking the head off?
Old Oct 3, 2005 | 11:38 AM
Spax's Avatar
Spax
Yes it is, My local Ford garage changed mine for £70 that included an oil n filter change too
Old Oct 3, 2005 | 11:40 AM
Yes, if you have some way of holding the valve shut, compressed air for example.
Old Oct 3, 2005 | 11:41 AM
antony215's Avatar
antony215
Escort Rs Turbo
yes you can burtons do a tool for about £9 and the seals are about a £10 from them two
Old Oct 3, 2005 | 11:44 AM
xfactor's Avatar
xfactor
Tool should be available from any good mechanical tool shop or auto factors. bolts to rocker studs then can be wound down to compress spring. make sure the piston is tdc on the chamber you are working on, this stops the valve dropping out
Old Oct 3, 2005 | 11:48 AM
antony215's Avatar
antony215
Escort Rs Turbo
This is what you want
www.burtonpower.co.uk
Old Oct 3, 2005 | 12:00 PM
Physio's Avatar
Physio
Yes you can mate - & quite easy to do with the correct tools
Old Oct 3, 2005 | 12:23 PM
GTechR's Avatar
GTechR
Mark... I have one in my toolbox... Bell me
Old Oct 3, 2005 | 12:27 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
can a "compotent" mechanic wanabe do it?
Old Oct 3, 2005 | 12:42 PM
Badman38's Avatar
Badman38
yes piece of piss to do
Old Oct 3, 2005 | 12:46 PM
excursion's Avatar
excursion
Bulletin Board User
cheers for the help lads, appreciated
Gaz - will get in touch, cheers mate!
Old Oct 3, 2005 | 02:58 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Yes, until you drop a Collet down an Oilway.
Its a fiddly time-consuming job. Well worth the £70 mentioned above IMO! It only takes to drop one Collet and its turns into a bit of a nightmare.
Old Oct 3, 2005 | 03:06 PM
It's Czech Mate's Avatar
It's Czech Mate
@ dropping the collet....I dropped one first time I did it on my 16i....luckily it went straight into the sump and we got it out with a magnetic telescopic 'reachy' thing that I dont know what it's called...lol....which was nice!
Old Oct 3, 2005 | 03:22 PM
essexrsturbo's Avatar
essexrsturbo
even if you did drop one it would be fine.. the amount of sumps ive found with these in and have been spot on. most important thing is not to drop a valve!
Do you really think your local ford dealer's YTS kid apprentice is any less likely to drop a collet than you are?
And if he does, do you REALLY thing he will tell anyone? :cry;
Old Oct 3, 2005 | 04:54 PM
rs_daz's Avatar
rs_daz
Tissue in the oil ways never lost a collet yet and done loads lol
Old Oct 3, 2005 | 04:55 PM
Christian and Beccy
#1 in Spelling Club
But to change Valve Stems Seals without dropping a valve is a piece of piss. You can be as careful as anything and still drop a Collet. Thats why its better to pay someone IMO, at least there is a chance that you may not have to sort it. Personally, I take precautions when changing these to reduce the chances of this happening.
Old Oct 3, 2005 | 05:04 PM
rs_daz's Avatar
rs_daz
as above
Old Oct 3, 2005 | 05:06 PM
Gra's Avatar
Gra
peice of piss with right tool, my local motor factor charged me £6 for mine
Old Oct 3, 2005 | 06:17 PM
M Brian's Avatar
M Brian
check your local halfrauds tools reduced bin!! there were loads in my local one about a month ago-mustnt be much call for them now
I Paid £4 for my sykes CVH compressor tool. better quality than the burton type IMO.
shame it was a replacement for the one I lost (I paid full price of £13.99 a few years back )
Old Oct 3, 2005 | 06:51 PM
Lee Reynolds's Avatar
Lee Reynolds
yep very easy. Block the oilways with small rags incase you drop a collet! NOT TISSUES as mentioned above Tool available from halfords etc..kinda replaces the rocker and compresses the spring. Remove the plugs so you can check that whichever inlet and outlet you are working on the piston is at the top! The vlave wont drop with the piston at top...
Old Oct 3, 2005 | 06:53 PM
RS ONION's Avatar
RS ONION
halfords do the tool , n when i did mine i dropped two collets down the oil gally n ended up taking sump off ha ha use a magnet to take off n put back in ...
Old Oct 3, 2005 | 06:58 PM
EvilFranky's Avatar
EvilFranky
When my FRST engine was rebuilt we found a collet in the block
Someone had obviously done it previously on the car and made a bit of a pigs ear of it
Old Oct 3, 2005 | 07:10 PM
GTechR's Avatar
GTechR
He collected mine this afternoon and was give vague instructions on how to do it
Matt Baxter
Sep 16, 2015 08:30 PM
Danielbetty
Aug 28, 2015 08:01 PM
Chopshop85
Aug 17, 2015 06:38 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
rsstav
Aug 11, 2015 04:22 AM
