Why my music sound crappy?
Old Oct 2, 2005 | 12:25 PM
Thrush's Avatar
Thrush
Irritating c........
Default Why my music sound crappy?
Right, the set up I have it I have a 60GB HDD (HD1) as primary which runs Windows OS and all processes, programmes etc...
I also have an 80GB HDD (HD2) as slave that is just formatted to NTFS and I use as mass storage - mostly music and video files, with also pics and all the exe/set up files for the programmes I have downloaded and installed.
the idea behind this was that in the event it all goes tits up with a currupted OS or a virus fucks my primary HDD then I don't loose all my data as 90% is stored on HD2 - and once an OS is back on HD1 then installing the programmes I use is easy as I already have all the set up exe's.
Anyway, this worked great for a little while - HD1 would operate Windows Media Player, and the music would come from the music files stored on HD2. But a few days leter I started noticing that the music was getting a few hic-ups, blurrs, pop's, crackles etc... And it has been getting worse - from one or two tiny intrusions in a song to it being literaly every beat - it's like listeing to an old record!
But I made a discovery yesterday, and that if I copy a track from a CD onto HD1 and copy the same track onto HD2 and play them back one at a time : HD1 track is faultless. Completely clean and intrusion free. But the same track played from HD2 is full of pops and farts
So what I want to know is what is most likely causing this?
It's not like the CPU is over loaded - I checked and whilst running WMP and a track from HD2, with 2 or three IE windows open and a download going on the CPU performace is still low. I would have thought that running two drives at the same time would be BETTER as you have two seek times, two sets of RPM, instead of one drive trying to do it all.
I don't think it is heat related as as it does it straight away - after it has been off all night, and only just turned on - and does the same when it has been on all day.
So could it be that HD2 is sticking? Or unbalanced in some way? Or could it be a compatability issue?
Any idea's?
Old Oct 2, 2005 | 04:11 PM
Thrush's Avatar
Thrush
Anyone?
Old Oct 2, 2005 | 04:19 PM
xpackcapri's Avatar
xpackcapri
Old Oct 2, 2005 | 04:48 PM
Thrush's Avatar
Thrush
Right, I think I followed you, but to be safe I took a screen shot of where I ended up;
Old Oct 2, 2005 | 06:16 PM
DanRSturbo's Avatar
DanRSturbo
I'd of copied a track from hard drive 2, to hard drive 1 and tested it Alos, install winamp
Old Oct 2, 2005 | 06:36 PM
Thrush's Avatar
Thrush
I have never linked WinAmp - and I have copied a track from HD2 to HD1 and tried it;
On HD2 I get a few pops, crackles + slurs - same track played from HD1 (primary) is spotless throughout, as I said in my first post.
Old Oct 2, 2005 | 08:20 PM
DanRSturbo's Avatar
DanRSturbo
I'd be backing up your MP3 collection sharpish then
Old Oct 2, 2005 | 08:26 PM
Thrush's Avatar
Thrush
Do you think it is a problem with this particular HDD then (HD2) ? Possibly going to fail?
Old Oct 3, 2005 | 10:03 AM
DanRSturbo's Avatar
DanRSturbo
It sounds like there could well be, maybe a scandisk and a defrag could resolve it
Old Oct 3, 2005 | 05:42 PM
Thrush's Avatar
Thrush
Would a defrag help? When I fitted it up as a slave drive I did a full format and completely wiped it so there shouldn't be anything on there other than the MP3's I have put on....
It's behaving perfectly right now, and was pretty much fine last night aswell. Sometimes it just doesn't like to play ball
Old Oct 3, 2005 | 11:02 PM
DanRSturbo's Avatar
DanRSturbo
Typical computers
Old Oct 3, 2005 | 11:08 PM
xpackcapri's Avatar
xpackcapri
Old Oct 4, 2005 | 09:23 AM
Thrush's Avatar
Thrush
Okay - so how do I change this?
Old Oct 6, 2005 | 10:40 PM
xpackcapri's Avatar
xpackcapri
Old Oct 8, 2005 | 03:06 PM
Thrush's Avatar
Thrush
On the drop lists I only get "PIO ONLY" and "DMA IF AVAILABLE", and the box underneath, I can't change anything in it...
Old Oct 8, 2005 | 04:42 PM
xpackcapri's Avatar
xpackcapri
Old Oct 8, 2005 | 08:43 PM
Thrush's Avatar
Thrush
Yes. CD drives are set to CS on IDE2, and the HDD's are set as CS on IDE1...
I am sure I read something about drive noise reduction or something that makes drives run slower so as to be quiter, but you can disable it and they run at full speed, but will become noiser......? I shall have to find the link, think it was a Dell site page...
Old Oct 9, 2005 | 05:28 PM
xpackcapri's Avatar
xpackcapri
Old Oct 9, 2005 | 05:47 PM
Thrush's Avatar
Thrush
I found another forum called the XPFORUM and posted on there. The first reply said to go into SYSTEM>HARDWARE>ATAPI tree, right click PRIMARY and uninstall it, then reboot, so I did all that.
When it booted up it did the whole "new hardware found" thingy and asked me to reboot again.
The idea was that he said when it boots up again it should read DMA 6 or somthing in there, but after the final reboot it is exactly as it was before, so that achieved nothing
Kiran1600E
11
Oct 2, 2015 11:35 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Fudgey
21
Sep 30, 2015 06:19 PM
