Breaking ERST most bits avaliable NEED IT GONE - OFFERS PLZ!
I am now breaking the car as have taken out what I want/need so rest is suplus to requirements
Bootlid with 90 spec spolier, no rust - £60
90 spec front and rear bumpers - £50 for both bumpers
Inlet manifold, sandwich plate and throttle body £25
Charge carrier - one in pic £25
Pipercross induction kit with miurage stainless heat shiled for metering head £40
Doors with all electrics/mirrors (both doors) - £30
Complete glovebox x2 - yup u guessed it MINT - £10 each
Ignition and Fuel ECU's - both modified
Metering head
ERL MF2 5th injector
You know the score, pictures of car can be seen at this link, if you can see it - likely hood is IT IS for sale!!
http://photobucket.com/albums/0803/JamesRaby/F56%20BDA/
Metering head
the exhaust is currently down my local garage
Age, I'd guessing at this but maybe just over a year maybe not even that
condition wise, clean as a whistle
I will get some pictures for you on Monday
Ballin, no it's not - pic tomorrow, look ok though
Parky, not far to look really
Originally Posted by James Raby
Cossie rims, been offered £350 so far
Originally Posted by CabrioTurbo
how much for the MF2 mate? is it complete with pressure switch-red loom etc?
Phil
Phil
I have the MF2 and it's on my cold start constant feed for fuel, Gary @ APT wired it all up
might be worth giving them a buzz for exact details
But it's on my Blue one right now without any issues what-so-ever, got the loom for it, connectors etc etc etc
lovely colour tho
do you have a really nice clean rear boot thingy
you know the thing ya can cut holes out of to house speakers lo
(its been that long since i had mine back i fooking forgot the name, i kid ya not
you know the thing ya can cut holes out of to house speakers lo(its been that long since i had mine back i fooking forgot the name, i kid ya not
Ian, I like the colour - especially when its got rain on it (looks awesome) and still like it now (needed a good polish tho)
I believe you're wanting some rear shelf supports? am I correct
Rick, it's on ebay mate http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=4579743708
can't edit or remove item as it's less than 24 hours of auction ending
Pretty sure that the highest bidder has bidded about £55.00
POSTAGE IS NOT A PROBLEM, WILL BE PACKED WITH CARDBOARD AND BIBBLE WRAP
to the top
Interior (full 90 spec trim) £150
Bodykit £45
Bootlid/spoiler £60
Front/rear bumpers £60
Mongoose £150
Doors - £30 each comes with all the stuff with each door
Bilstein suspension - £160
Gearbox (made no noises at all and did 139mph @ brunters) £200
Calipers/pads - £20
Oil breather/pipes £40
Centre console - £10
I need it all gone
Bodykit £45
Bootlid/spoiler £60
Mongoose £150
Calipers/pads - £20
I need it all gone
lol not been online much recently mate!
has the MF2 got the loom that can connect up to a 'normal' bosch injector as i already have one welded in my charge carrier and dont really want to use the cold start valve
CheeRs
Phil
CheeRs
Phil
Come again??
Why would you use the cold start valve??
It's got the boss kit for a charge carrier adaption which I am currently using a Green injector for
thats ok then
you can get a loom for one of the 5th injector kits (may not even be the MF2!) that can connect to the old start valve so it can be used as an extra injector... so how much do you want for it!
Its not a huge order, but I need the two horseshoe clips that hold the shaft that goes through the clutch and brake peddles........I was changing the clutch ratchet and lost one, but if you have them I'll take them both just to be on the safe side. Cheers
thats ok then
