biggest alt on a mk 4 is?
i need to upgrade my alt , my bass amp is pulling up to 120 amps on full load , my alt i belive is 70 amps, i can get a 150 amp alt, but its 170 pounds, so is there a ford alternative i can use ??
thanks in advance guys.....
ive just changed the wire from the alt to starter and on to the battery , ive also changed all the earthing straps , and got a bigger battery now, voltage is sitting nicely at 13.9 volts with it on 2 rds volume [ pulling 120 amps
see the thickness of the purple wire on the right ? that now runs from the alt to the starter to the battery
battery
battery
Bailes1992
Sep 19, 2015 02:17 PM
Ben26
Aug 27, 2015 08:56 PM
