BRAKE LIGHTS
mine aint working on the GLSi. peeps keep tooting me
i've cleaned up the terminals on the clusters and checked the fuse's and all seem ok
what else can i check?
as said before check the switch m8.....pull the plug off it bridge across the terminals in the connector, turn ignition on n see if lights come on if they do then new switch needed
Dr. Ickxs
Sep 15, 2015 10:15 PM
