Testing compression
Old Sep 28, 2005 | 06:07 PM
excursion's Avatar
excursion
Bulletin Board User
Default Testing compression
Hi all, what figures should I expect on a compression gauge (psi) when testing a freshly rebuilt standard comp engine?
Just wanna make sure everythings OK.
Cheers.
Old Sep 29, 2005 | 10:56 AM
excursion's Avatar
excursion
Bulletin Board User
BTTT
Old Sep 29, 2005 | 11:58 AM
davidnormanuk's Avatar
davidnormanuk
You should be getting arounf 125PSI.
Dave
Old Sep 29, 2005 | 03:51 PM
addiction's Avatar
addiction
Old Sep 30, 2005 | 08:20 AM
JesseT's Avatar
JesseT
As even numbers as possible. The value itself depends greatly on the cam. On a standard cam around 10 bar (147psi) is common. A bit less with a hot cam.
Old Sep 30, 2005 | 08:25 AM
excursion's Avatar
excursion
Bulletin Board User
Excellent. Thanks for the help, appreciated
TPM961
Jan 15, 2018 10:50 AM
Prickly_buzz
Dec 7, 2017 09:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
