how many places can an rs turbo engine leak oil from
Old Sep 28, 2005 | 04:30 PM
Combi_Chris's Avatar
Combi_Chris
Default how many places can an rs turbo engine leak oil from
whats the most common places an rs turbo is know to leak oil , ive recently changed the head gasket for a ford one , sump is next , anywhere else worth doing as a precuation , or should i wait untill i find a leak as disturbing things isnt always a good idea right ??
Old Sep 28, 2005 | 04:33 PM
GrimmeRS2K's Avatar
GrimmeRS2K
crankseal, dizzy.
Old Sep 28, 2005 | 07:44 PM
Combi_Chris
is the crankseal a messy / long time consuming job ? ?
Old Sep 28, 2005 | 10:39 PM
GrimmeRS2K's Avatar
GrimmeRS2K
yeah, dont do it untill u know its leaking, mine failed i found it quicker and easier to just take my engine out and do it!
if u do change make sure u get the seal carrier aswell, as most of the time the new seal will just leak
Old Sep 28, 2005 | 11:09 PM
adamS2RST's Avatar
adamS2RST
Too many places
Old Sep 29, 2005 | 10:02 AM
Combi_Chris
well ill do the sump, and see what happens , can removing the gearbox make it quicker for the crank seal , as my box is coming out over the winter..... adams2rst, sounds like your having some bad luck ??
Old Sep 29, 2005 | 10:13 AM
adamS2RST's Avatar
adamS2RST
Na, luckily not, and never really had any oil leak problems... Petrol leak problems before...but that's another story
Old Sep 29, 2005 | 03:55 PM
addiction's Avatar
addiction
front crank seal is relatively easy to do, need to take the box out for the rear one though,and the clutch and flywheel off.
Old Sep 29, 2005 | 05:19 PM
Moonie's Avatar
Moonie
If its not broke, dont fix it!
Old Sep 29, 2005 | 05:25 PM
Combi_Chris
well moonie i have a smallish leak , ill get the sump done as amatter of course, then re - evaluate the situation....
Old Oct 2, 2005 | 09:12 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Don't under estimate changing the Sump/Gasket. It is a bitch to get them to seal.
Where is the oil?? Bottom of Starter? If so, my moneys on a Split/Perished Oil Drain hose. If so, part with your Ł35odd to Ford for a replacement!!
Trace where on the engine it is coming from before wading in and taking stuff like Crank Seals and Sump Gaskets on IMO.
Old Oct 3, 2005 | 08:15 AM
John Laverick's Avatar
John Laverick
If you end up doing the rear oil seal....MAKE SURE YO REPLACE THE ALLOY HOUSING AS WELL!!!!
I changed the seal twice and it was still leaking!!! Replaced it the 3rd time with the housing and now its sorted.
For the sake of Ł35 I'd change the housing every time!!
Old May 20, 2006 | 06:45 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
I've got an oil leak, too. Looks like gearbox oil. It is gathering in the engine subframe and then drops onto the ground. Any common places where it could come from?
Old May 20, 2006 | 07:47 PM
SafeChav's Avatar
SafeChav
Originally Posted by adamS2RST
Too many places
I hear that
Old May 20, 2006 | 07:50 PM
shane's Avatar
shane
N/S Driveshaft seal?
Old May 20, 2006 | 08:02 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Ask Jano, I'm sure he'll be happy to help
Old May 20, 2006 | 09:09 PM
user 7082039239
Nope... Had a quick look around everything in this area but did not find anything unusual.
Old May 21, 2006 | 02:30 AM
Combi_Chris
i dont actually have any leaks though, i was only asking as a precautionary measure....
Old May 21, 2006 | 09:08 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
So you asked a question that has no real answer.
Just for the conversation.
Its an engine. Leaks are common from every crack and gasket.
Old May 21, 2006 | 12:10 PM
NIMRODS_RST's Avatar
NIMRODS_RST
MISSING MY RST!!
i agree with u there been there done that
Old May 21, 2006 | 12:15 PM
notSteveS2's Avatar
notSteveS2
i took engine out to swap it for better 1.... changed all gaskets while i was at it...
put it all bk in and started it up... realised i put wrong (damaged) sump on...
changed it whie it was on car up on jack... managed it ok... with help from a pal...
is ok up til now!
Old May 21, 2006 | 12:17 PM
SafeChav's Avatar
SafeChav
is ok up til now!
Jinxed it
Old May 21, 2006 | 12:22 PM
notSteveS2's Avatar
notSteveS2
dont say that...........
lol
sssssshhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Old May 21, 2006 | 12:36 PM
SafeChav's Avatar
SafeChav
I already did
I'm SORRY unchballs:
Old May 21, 2006 | 12:39 PM
notSteveS2's Avatar
notSteveS2
big_Rad
Sep 15, 2017 09:36 AM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
mattman1234
24
Aug 1, 2015 11:46 AM
