any microcat experts about??????????
im trying to find the part numbers for some front spot lamp connectors on a focus,trouble is its the "collection" edition and i can only find normal fog lights for a standard focus,how do you go about finding these diff versions?
Hi mate .. You have just the man here .. as I am the one and only guy who looks after all the wiring for Focus CAK, CAP and C-Max .. not to mention a few others ; )
That is what is called a Supplier-branded part through Ford marketing, or VPP (Vehicle personalisation Product)
Can you forward me the exact model Focus (year) and any tag number you can find on the extra wiring loom. I take it you checked the O.E. Fog lamp connectors I have listed (and placed a description on) in the connectors section on Microcat/eCat? 4180120 or thereabouts!
Those connectors are available .. I have a few other spares in my office. The Main Headlamp and Fog wiring is part of the Main wiring tho ... 14K733 base.
Let me have the details and I'll see if I can match up the parts from the drawings over the next day or so
what im actually after are the plastic caps/holders? that fit on the back of the lamps,keep the rain out,[these are normally a twist in type fitting]but on these they are held in place with a couple of screws the caps have the wiring connected in them and then the ford wiring just plugs into the back of them if you know what i mean?
Hi again ...
Like most of the lamp sub-assemblies, these will probably only be available as part of the lamp
But I'll have a look tomoz. Is this car Mk1/2 saloon? Or New shape?
Will put up the Pipe layout tomorrow Dave. Maybe stick it in the Escos Dept!
Ah! But I thought I could get the bits .. Im waiting for the manufacturers to call back .. but I think in the end you'll need to get the lamps. Theyre 83 quid retail
each ...
Cheers ...
each ...Cheers ...
DavidK
Sep 27, 2015 02:55 PM
fireandskill1
Nov 16, 2004 07:56 PM
they are round ones as opposed to the usual triangle shaped ones normally found on focuses
