XR4X4 FRONT SHAFTS IN A COSSIE??
Old Sep 27, 2005 | 04:56 PM
safflad's Avatar
safflad
Default XR4X4 FRONT SHAFTS IN A COSSIE??
I know they look almost identical but a little longer but is there a paticular order (ie hub/diff end first) fitting them? what are the affects of fitting them in wrong order? pls help any advice gratefully accepted cheeRS
on o/s front by the way car is a 4x4saff thats been lowered approx 45mm
Old Sep 27, 2005 | 05:04 PM
Dean Saff's Avatar
Dean Saff
fit them diff end in first mate as you would a standard shaft
Old Sep 27, 2005 | 05:08 PM
safflad's Avatar
safflad
oh the problem i have is a juddering when i turn left since i fitted the new shaft and a reputable specialist told me the opposite but i can't see what difference it makes
Old Sep 27, 2005 | 05:37 PM
Dean Saff's Avatar
Dean Saff
I dont understand what you mean?
Once fitted if its juddering maybe a bad cv joint??
Did you do up the hub nut tight? any play anywhere in the wheels?
I cant see why you would fit it to the hub first, But ether way it shouldn't make a difference.
Old Sep 27, 2005 | 06:18 PM
ian sibbert's Avatar
ian sibbert
xr4x4 front shafts are 8mm longer than cossie shafts as such you should have the circlip groove on the shaft that locates the cv machined 8mm further in effectively reducing the length....they should be installed diff end first then the hub end....they will fit and may not have any detrimental effect but the longer shaft alters the plunge depth of the cv and can lead to premature failure of the cv joint...
Regards
Ian
Old Sep 27, 2005 | 07:12 PM
Jim Galbally's Avatar
Jim Galbally
people normally fix XR ones on lowered saphs/esccosies coz theyre longer and less likely to pop out
Old Sep 27, 2005 | 07:15 PM
dave cos4x4's Avatar
dave cos4x4
fitted them in my cars with no probs at all.
Dave.
Old Sep 27, 2005 | 08:17 PM
Graceland's Avatar
Graceland
Team HOTHOT!
got em in the front on my taxi - no problems at all and cured its hunger for offside front inner CV joints
Old Sep 27, 2005 | 11:28 PM
HYBRiD_T's Avatar
HYBRiD_T
Collins Engineering do a conversion to standard 4x4 shafts. It costs around £60 per shaft. They remove the standard inner casings and machine thicker interference fit alloy casings in there place.
They told me that they run them on lowered 600bhp+ Escort Cosworths on 19's with 255mm tyres with no problems.
I had mine uprated by them and can highly recommend their work.
Old Sep 28, 2005 | 12:12 AM
safflad's Avatar
safflad
can only assume its down to the numptee that fitted it then(me)I'll have a good poke about tommorrow and see if swearing at the ruddy thing a bit more helps cheeRS lads
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
cossie330
Aug 22, 2015 12:00 PM
C2 MAK
Aug 20, 2015 09:46 PM
RockinRein
Aug 19, 2015 07:08 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
