S1 fuel problem
Old Sep 20, 2005 | 08:07 PM
nice_head's Avatar
nice_head
Default S1 fuel problem
Got a series one which is running on LPR petrol at the mo.. The thing is I cant get hold of this fuel anymore down my way..
Is there anyway I can use unleaded fuel without damaging the engine??
Old Sep 20, 2005 | 09:06 PM
Alps Pacino's Avatar
Alps Pacino
I would run optimax possibly with an additive of some description
Old Sep 20, 2005 | 09:28 PM
Oranoco's Avatar
Oranoco
LRP is fucking awful fuel. Seen the tests that were done on a SAAB turbo. The engine was shot after being run on it.
It should run on Optimax fine but consult a tuner. May need the head fiddling but what better excuse to polish and port the head while it's off
Old Sep 20, 2005 | 10:10 PM
Karlos's Avatar
Karlos
if ur gonna start takin the engine apart may aswell get it converted to unleaded
will b ok on super unleaded or optimax as long as used wiv LRP additive
Old Sep 21, 2005 | 10:20 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Why cant you just run unleaded and get the ignition set up?
Old Sep 21, 2005 | 11:02 AM
Oranoco's Avatar
Oranoco
I thought if the head had LPG stamped on it above one of the exhaust ports it would run on SuperPlus with no modification?
Old Sep 22, 2005 | 01:17 AM
and.rs1800's Avatar
and.rs1800
my series1 runs fine on unleaded.i just use optimax,no additives.mines a late 1985.if i cant get optimax i bung in a fivers worth of super from whatever garage,then stick some optimax in when i find a shell garage.
Old Sep 22, 2005 | 02:16 AM
wildheart's Avatar
wildheart
It will run fine on super unleaded/optimax.
If they dont sell that near you then use this http://www.castrolclassicoils.co.uk/valvemp_new.htm
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
RSBryden
Sep 6, 2015 08:39 PM
