FAO: Experts, ALS Help Please
Old Sep 17, 2005 | 04:20 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Default FAO: Experts, ALS Help Please
Right, the car is going to be mapped soon so I need to decide on what to do about the ALS. I have a Maram shaft and want to make full use of it and have some decent ALS for inbetween the gears.
What is te best way to do it?
I mean, should I get my throttle body ported and run an ALS valve, or get throttle body ported and modify the ISCV, or just modify the ISCV, or something else...
Of course I would still like a decent idle from cold if possible, but does that have to mean that I need to run an ALS valve and a ISCV, if so, how?
I don't see the point in having the turbo and the ECU to do it properly and only just about make positive boost. Please help me.
Thank you
Old Sep 17, 2005 | 05:54 PM
M K's Avatar
M K
ive heard you can run two valves as im sure some 1 on here has it???
im gonna be running just the modded iscv wih my group a cossie tb,,,
Old Sep 17, 2005 | 05:56 PM
Karl's Avatar
Karl
Norris Motorsport
If its a road car then don't bother with ALS.
Old Sep 17, 2005 | 06:05 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Why karl
Old Sep 17, 2005 | 06:10 PM
Ginge !'s Avatar
Ginge !
just finding my feet
the noise, the heat adn the fact its pointless on a few car
well unless ya wanna cruise on idle popping and banging then go for it
oh and ya cant engine break with ALS as the car will go faster
Old Sep 17, 2005 | 06:20 PM
DaveEscos's Avatar
DaveEscos
where DO you find all the bolocks you preach!
Old Sep 17, 2005 | 06:21 PM
Karl's Avatar
Karl
Norris Motorsport
Why?
Because the majority of people who have it fitted do not use their cars for competition use. When I build a competition car I will go to every length possible to make the car a class leader and that includes ALS if it helps.
If its a road car then ALS can only be to impress chav's and girlies, so I frown on applications like this!! It shortens turbo and engine life, especially the thermal fatigue on exhaust valves and causes cvh engines to lose exhaust valve heads on a regular basis. On a competition engine where the engine only needs to run for a few hours between rebuilds this is acceptable but for a road cvh engine it is disaster waiting to happen!!!!
Old Sep 17, 2005 | 06:23 PM
Charlie Chalk
Unknown.
Fari enough karl, I agree on the chav bit, thats not my scene
Im still undecided to have it on my Track S2
Old Sep 17, 2005 | 06:24 PM
Rick's Avatar
Rick
I might add that if its a proper engine u dont get lag between gears either - i certainly don't.
Old Sep 17, 2005 | 06:25 PM
Benn 304R's Avatar
Benn 304R
totally agree woth Karl on this matter.
Old Sep 17, 2005 | 06:50 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
BANG goes my pulling young chav birds rating 'scuse the pun pmsl
Old Sep 17, 2005 | 07:34 PM
M K's Avatar
M K
as for the heat side of things cant you use the more resistant sodim filled valves???
thats what ive been offered to have put in a head i might have built by field motorsport?
Old Sep 17, 2005 | 07:36 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
My opinion on ALS has changed alot in recent times.
I think people are under the impression that it will make a laggy turbo into one that isn't laggy. OK, so if you could engineer the whole package to take lots of ALS as per a Rally car, then fair enough, but if you can't then the balance of what there is to gain, against the risk of running it makes it not really worth pinning your hopes on.
Besides which, the RST Gearbox is looking for every opportunity to have its Internals re-arranged, why make it worse?
I will probably have it, and have the facility for a totally separate ALS Valve already in place, but I don't really plan on using it (except to impress the Chav's ). But I'm wise/disciplined enough to understand that my car isn't indestructible and her indoors has made it perfectly plain that if it breaks again, it goes in the garage and stays there for a very long time.
Old Sep 17, 2005 | 07:39 PM
Charlie Chalk
Unknown.
Poor sod
Old Sep 17, 2005 | 09:35 PM
Ginge !'s Avatar
Ginge !
usually by talking to people on the net when asking em questions
i used to wonder what ALS was as steveN had it on his 3 door and so was gettign info about it, wanted to know if it ant be available on a erst and then it got all techy and i got lost, all i remember was ALS killed gearboxs and caused loads of heat and then main thing i remember hearing was it due to the idle by pass if you engine braked it would not lower the revs but keep em up for some reason
but dont worry as then you got ALS fitted to ya car and noticed it was fooking LOUD and really just for looks ( or attention) and then jano got it and,,,,,,,,,,, well the rest is history
ALS is not for a road car as the point of it is for real performance cars to give the few seconds difference but for road use if ya wanna save 3 seconds turn off ya stereo and aircon
dave just wondering your antilag, was if full bore or was it just mild and 0 psi on idle, always wondered and this seems a good time to ask
also did ya find it any better as such on a t34 car
and is there a quiet version of it available as its fooking too loud
Old Sep 18, 2005 | 03:35 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
I have ALS on the XR3 which has done 28,000miles some road, some race drag or track events with no engine problems or turbo problems. This is a CVH 1600 without 247 shaft.
I have built 16ZT with ALS 7psi@idle done over 3000 miles with no problems.
Series One 1600 CVH has now done 500miles some track use at silverstone and brandshatch with and without ALS on a STD shafted Turbo with no problems!
A customers ERST 1600cvh used for hillclimbing is now second in his class using the aid of ALS & Dizzyless He was 5th!. 1st in his class is a full blown MistyEvo.
ALS does help when running for races, drag etc.. On the road it is a little extreme but when in control can be fun The reason it is fitted to ours is because we run P8 with dizzyless, when you have this conversion its only another Ł200 for ALS
The heat and engines blowing up is a myth as far as im concerned. Our maps take everything into account. If the ACT temp is higher than 35degree the ALS will NOT come on when switched on. If on for more than 10seconds and not used it will switch off. If ACT temp rises switched off + loads of other safety measures.
Regards
Old Sep 18, 2005 | 03:45 PM
Ginge !'s Avatar
Ginge !
thats a class touch
does it stop the car engine braking btw ( i know ya dont usually have anti lag on when driving but im sure ya have once )
Old Sep 18, 2005 | 09:43 PM
Versus_Creations
Ask me a question!
Just cos i dont use it going round a sea front doesnt meen that i dont use it on the track, drag or brunters etc..
Nothing can stop the engine from braking unless you build it right and look after it right! The main things that will break is your transmission Hence why my engine is out having the MTX75 fitted
Old Sep 18, 2005 | 09:51 PM
M K's Avatar
M K
no he meant does it stop you braking with the engine,,,i.e with the gears
think thats what he meant any way???
Old Sep 18, 2005 | 09:57 PM
Christian and Beccy
#1 in Spelling Club
It does make your brakes shite too, due to the lack of Vacuum for the Servo.
Old Sep 18, 2005 | 09:58 PM
Charlie Chalk
Unknown.
Thats why i'll be running a pedal box
Old Sep 18, 2005 | 10:00 PM
Versus_Creations
Ask me a question!
On FWD you have to turn ALS OFF into corners anyway as the car losses traction otherwise, due to the fact that you cant feather the throttle like you can with ALS OFF. When on and trying to turn corners hard and control with Throttle its hard
Have a look at a couple of the Vids
https://passionford.com/forum/viewtopic.php?t=130383
Old Sep 18, 2005 | 10:05 PM
Karl's Avatar
Karl
Norris Motorsport
LOL still a wannabe's chav mod if fitted to a road car LOL
Old Sep 18, 2005 | 10:40 PM
Versus_Creations
Ask me a question!
So how about if it is per rally car then would it be ok? I.e The Management Dizzyless, Cam & CPS sensors, Turbo, Engine and Throttle body and ISCV.. Then would it be ok?
A Laggy Turbo becomes instant with ALS. If desired you can run with Pectel 12stage+1 variable boost via Air injectors to add a lilte adjustment with ALS. If you dont have AIr Injectors you can set the ALS level via the ECU and also via hole sizes etc..
Also when you have ALS because you have a P8 and coil pack you get the larger spark which obviously gives you better response, power etc..
On my 1600cvh I gained 14 bhp when uprated to P8 with dizzyless this could be done due to a few reasons but one would be the extra amount of advance, higher boost you can run depending, better mapping, etc etc..
Just a little more to talk about
Old Sep 19, 2005 | 07:47 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Tony,
What-ever you decide, I can supply the ALS valve, the modified ISCV and the modified throttle body... .
I very rarely turn the ALS on on the road, as it is a bit anti-social, but it is great on track .
Old Sep 19, 2005 | 08:07 AM
Azrael's Avatar
Azrael
I was told by Norwegian guys running 3-door Impreza in european rallycross championchip that special ecxhaus design can reduce nose. I am not quite sure but either ALS is illegal in ralycross sort of limiting turbo size, or the nise level would be illegal with standard setup. Anyway on their car as on most top rallycross car's you can't hear the "bang bang" from the exhaust only loud noise of air going back through air filter. But they got massive exhaust I think it maybe 4 or 5 inch at some sections.
Old Sep 19, 2005 | 09:04 AM
Versus_Creations
Ask me a question!
Tony,
How much out of intrest?
b
Old Sep 19, 2005 | 10:28 AM
RichardPON's Avatar
RichardPON
Personally I can't see it!
Firstly you can't use it on most track days as it flips the noise meter straight away.
Secondly, where is the lag on track? If the engine is built correctly, and the cams/head porting/turbo all matched, then why the need for ALS? Where does it come in on circuit use?
Old Sep 19, 2005 | 10:31 AM
Azrael's Avatar
Azrael
Well, some circut racing cars use it. Improves throttle responseat the expense of rather agressive engine behaviour. I think GT cars in Japan use that.
Old Sep 19, 2005 | 11:16 AM
Mike Rainbird
Caraholic
PON,
Shows how much you know about ALS and turbos .
ALS does not reduce the boost threshold, but keeps the power in between gear changes. All I would have to do is show you the difference with the ALS on and off and you would not believe the difference it makes . Off, and the boost drop is extremely noticable; On, and it drives like a T3 car in the way there is minimal drop between gears .
Also, although I can't get away with it at Bedford, I can at Snetterton (my local circuit ), Donington on noisey days (basically the only time I go) and the 'Ring, so it's good enough for me .
Old Sep 19, 2005 | 11:26 AM
RichardPON's Avatar
RichardPON
Sorry, I still can't see it.
You're talking about reducing the lag by fractions of a second - how is it even noticeable?
Surely the only thing that's making any sort of lag an issue is the time it takes to change gear on the shonky standard pattern box?
Old Sep 19, 2005 | 11:42 AM
Mike Rainbird
Caraholic
PON,
Obviously I'm wong (having experienced ALS) and you're right (having never experienced ALS) .
Old Sep 19, 2005 | 11:43 AM
Mike Rainbird
Caraholic
Originally Posted by Jano_OddKidd
Tony,
b
For which bit?
Old Sep 19, 2005 | 11:54 AM
Mike Rainbird
Caraholic
So what to do? Mmmm let me see, fit Ł9k of noisy dog box highly unsuitable in a road car, or spend a Ł1k extra (Maram shafted T4 and all the genuine works spec ALS bits) and have ALS - it was a REALLY tough decision .
Old Sep 19, 2005 | 12:14 PM
RichardPON's Avatar
RichardPON
No fair enough.
I reckon that Ł1000 was well spent for Snetterton once a year, and Donnington once a year
Old Sep 19, 2005 | 12:23 PM
Mike Rainbird
Caraholic
PON,
It's a one off expenditure and I have used it on every track day I have ever been to , so that's 6 track days a year plus Nurburgring twice a year - EVERY year . Obviously it gets you black flagged at Bedford, but is still used even if it is last session of the day .
Old Sep 19, 2005 | 12:57 PM
Mike i have never had anti lag but the lag between gearchange's on yours with it turned on is no different to mine with it turned off.
Old Sep 19, 2005 | 01:03 PM
Mike Rainbird
Caraholic
You haven't got a shonky MT75 gearbox . You can't compare apples and oranges .
I LOVE Hippy's car in your sig .
Old Sep 19, 2005 | 01:10 PM
Thought we were comparing als and turbo's not gearbox's....
My gearbox act's as my als with not bang bang
Sig is proper
