RS TURBO BREAKING LOADS OF PARTS ;o) UPDATE PICS *******NEW*
might break the whole car if theres enough interest
spec as follows:
brand new koni's done 100 miles
chipped ecu
head with piper cam, vernier, new valve steam seals,
bottom end fresh with flat top pistons
stage 3 hybrid 7000 miles perfect
escos rims
black roose hoses done 100 miles boost+coolant
bailey dump valve
shell
rst front brakes grooved
magnex system flexi joint been welded
brand new cossie 4 pots machined 4mm ready to fit + rainbird lines
rainbird rear disc brackets + lines
powder coated blue rear arms anti roll bar few other bits
fresh powder coated black rocker cover
mint interior........................etc
whole car really. if theres enough interest i will break. pm me ring me 07919525645 or email deneo@dsl.pipex.com pics to follow @ the weekend
spec as follows:
chipped ecu
escos rims
bailey dump valve
shell
If you break can you let me know the condition of the dash, carpet and front door cards, and a and B pillar trims and all parts needed to put the seat belts back in mine and how much you would wnat for them??
Thankyou
Nick
Thankyou
Nick
Originally Posted by IANS2RST
price on the full car please & a full spec
UPDATE PICS
metering unit + lines and injectors £60
dump valve bailey £30
dump valve t-piece £5
intercooler only done 1500miles £466 new only £400 rad gen ford £30 few marks hold water tho
rocker cover £50 just shock blast'd and powder coated + new gasket
rs turbo to cossie 4 pot braided lines £30
bleed valve with silicon hose £10
polished x over pipe £25
coil £10
dizzy the little black plug is broken works fine tho £10
rs turbo front calipers painted blue pefect £25
tca's with polly bushes £30 gen ford
alternator bracket just shock blast'd and powder coated black £15
powder gear offers please would cost a fortune to do OFFERS + polly bushes
black silicon boost hoses roose done 50 miles as new £100
brand new 2wd rear discs £50
braided rear lines for rear discs £30
brand new rs 2000 hand brake cable only been put on car never used £20
rear disc conv brackets complete £30
rear lights smoked £30
fuel ecu £25
roose black water hoses only done 100 miles modified to stop hitting alternator mint £110
coil £10
fuel ecu £25
SOLD??
pm a price if not
hello mate well the calipers i paid £150 new £45 to have the machines and the lines we're £30 from rainbird. got a new set of ferredo pads too.
just make me a offer please mate.
dene
Originally Posted by XRT_si
How much did the Stage 3 go for mate>?
cheers dene
what are the model are the pads??
does the machine work mean the calpiers fit straight on??
could you email me some pics of the calipers as i would like to see them.
thanks
thanks
i will double check the pad and sort out a pic 2moro for you.
cheers
pic and price of konis please
muz
Aug 16, 2015 12:57 PM
155lee
Aug 14, 2015 11:21 AM
