best plugs and leads for 500 brake escos?
Old Jul 1, 2004 | 05:42 PM
Jon(m600)'s Avatar
Jon(m600)
Default best plugs and leads for 500 brake escos?
want to get some new plugs and leads for my car,but need to know which are the best.
Old Jul 1, 2004 | 05:45 PM
Kevin Sharp's Avatar
Kevin Sharp
NGK 9,s and standard leads
Old Jul 1, 2004 | 05:50 PM
Jon(m600)'s Avatar
Jon(m600)
Cheers kev arnt the ford motorsport leads more suited or they not needed.
Old Jul 1, 2004 | 05:52 PM
Kevin Sharp
i think the ends are bad for corroding on the motorsport ones jon the standard ford leads are very high quality
Old Jul 1, 2004 | 05:57 PM
Jon(m600)'s Avatar
Jon(m600)
cool m8 standard leads it is then.
Old Jul 1, 2004 | 05:58 PM
Billabong's Avatar
Billabong
It was only the 2wd leads that gave any corrosion issues (for some) I believe Kev.
Old Jul 1, 2004 | 06:04 PM
Kevin Sharp
i,v never had any probs with standard ones bill i had motorsport ones on for a year then started having probs so went to standard on tony,s advice
i remember Karl putting up a post about having probs with the motorsport leads corroding at the ends aswell i,m sure
Old Jul 1, 2004 | 06:08 PM
Billabong's Avatar
Billabong
Yep, remember the post (Karl's), just thought it was only the 2wd leads due to the angled ends.....and for the record, I agree that the genuine Beru leads are the danglies
Old Jul 1, 2004 | 06:20 PM
Matt's Avatar
Matt
nowt to do with the engled ends bill, its to do with the terminal connectors between the dizzy cap fitment and the lead itself becoming corroded as they are effectively a 2 part lead (utter shat design or what? )
not in this hp catagory at all but my car hated 909 leads at over 2 bar, now runs std beru with no issues
Old Jul 1, 2004 | 07:46 PM
justin.e's Avatar
justin.e
standard COSWORTH leads
Old Jul 1, 2004 | 07:49 PM
Stu @ M Developments's Avatar
PassionFords Creator
Bill is still correct in that the only leads afflicted are the early angled caps.
Escort Cosworths dont use that old fashioned cap
Old Jul 1, 2004 | 08:29 PM
Milko Pete's Avatar
Milko Pete
Not putting the Denso's back in then m8.
Old Jul 1, 2004 | 08:36 PM
Billabong's Avatar
Billabong
Denso plugs are fine too, IF of the correct heat range!
Kev, as Stu pointed out (cos on reflection I wasn't too clear in my post), I was ONLY referring to '909' 2wd leads, NOT the Ford Beru 2wd leads.
Old Jul 1, 2004 | 08:42 PM
Milko Pete's Avatar
Milko Pete
Its a running joke between us m8
Old Jul 2, 2004 | 01:20 AM
Fastmaul's Avatar
Fastmaul
K155MYRS
Are magnacores any good?
Old Jul 2, 2004 | 07:44 AM
Rene's Avatar
Rene
No .. only heard bad things about them
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
Mickeystewart
Sep 9, 2015 04:04 PM
stevierob
Sep 7, 2015 07:09 PM
