Ignition timing
Old Sep 9, 2005 | 11:53 AM
Rallyesport's Avatar
Rallyesport
Default Ignition timing
I checked my ignition timing yesterday with a timing light and it was at 8 degrees BTDC even though the mark on the distributor was aligned with the mark on the head. Might have been from another car. I set it to 12 degrees BTDC as Ford say. This goes for all CVH engines. Might I gain some power if I advance it some?
Old Sep 9, 2005 | 12:13 PM
GrimmeRS2K's Avatar
GrimmeRS2K
could gain a few horses, but dont they only advance if its pinking?
Old Sep 9, 2005 | 12:23 PM
JesseT's Avatar
JesseT
Yes you will gain much more, but you risk having detonation/pinking/knock. You will hear when this happens IF YOU KNOW EXACTLY what to listen. I hope you tuned it to 12degress without the ecu vacuum pipe and with proper low idle revs. Othervise you will still have too little advance.
Old Sep 9, 2005 | 12:50 PM
Rallyesport
Vacuum to ECU off and plugged, warm engine, idle speed, cooling fan on as described in Ford own workshop manual for RST.
Do they retard the timing at rolling road session on 200bhp/14.5+ psi engines?
Old Sep 9, 2005 | 02:43 PM
Rick's Avatar
Rick
No, they shouldnt.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
slammedorion
15
Nov 1, 2015 07:17 PM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
