ERST T3 and Sapphire cos 2wd T3
Old Sep 8, 2005 | 10:45 PM
Turbo-T34's Avatar
Turbo-T34
Default ERST T3 and Sapphire cos 2wd T3
Is there any difference?
Thanks
Old Sep 8, 2005 | 10:58 PM
GrimmeRS2K's Avatar
GrimmeRS2K
i think there is, cant think wot though
Old Sep 8, 2005 | 10:59 PM
antony215's Avatar
antony215
Escort Rs Turbo
Think there the same mate
P.S
Cheer's for that bleed valve i could'nt remember what your
user name was till i see your sig on this post
Old Sep 8, 2005 | 11:06 PM
GrimmeRS2K's Avatar
GrimmeRS2K
dont they have a .48?
Old Sep 8, 2005 | 11:10 PM
antony215's Avatar
antony215
Escort Rs Turbo
grimmeRST, Not sure i was told they where the same but you may be right
Old Sep 8, 2005 | 11:16 PM
Turbo-T34's Avatar
Turbo-T34
no problem on the bleed valve
is there any benefit for having a .48?
GrimmeRS2K's Avatar
GrimmeRS2K
almost certain they have a .48, and maybe a bigger compressor
if you look at the power a standard 2wd cossie turbo can flow, (around 280bhp)
i doubt u could put a t3 from a rs turbo onto a cossie and run 280bhp
Old Sep 8, 2005 | 11:18 PM
GrimmeRS2K's Avatar
GrimmeRS2K
.48 will give more lag IMO
Old Sep 8, 2005 | 11:40 PM
antony215's Avatar
antony215
Escort Rs Turbo
grimmeRST, you are right they do have a .48 and a .50 compressor
Old Sep 9, 2005 | 06:23 AM
Rallyesport's Avatar
Rallyesport
0.48 exhaust housing is a must have for strong top end power. Much stronger at the top, but you'll get more lag and max torque will move up the rev reange.
Old Sep 9, 2005 | 07:11 AM
Turbo-T34's Avatar
Turbo-T34
thanks!
So would a cam kit like a piper 285t balance it out by introducing torque from the go?
Old Sep 9, 2005 | 07:45 AM
ROLL GOLD DICE's Avatar
ROLL GOLD DICE
read the post - bigger turbo fitted - running problems, its on the same topic, still being discussed now ( i wanted to know a few things)
Old Sep 9, 2005 | 02:49 PM
Rick's Avatar
Rick
Yes, there is a differnece. The 2wd drive has a 55trim compressor wheel, as opposed to a 40 trim on the std RST item. It is essentially a bigger compressor wheel. Also has a bigger exhasut housing - 0.48 as opposed to 0.36.
Rick.
Old Sep 9, 2005 | 03:42 PM
cuvner's Avatar
cuvner
a cossie2wd t3 is not going to be soooo laggy on a bigger capacity erst engine because you will get more exhaust waste to drive it, yea?
Old Sep 9, 2005 | 04:24 PM
Rick's Avatar
Rick
Correct, but it's all linked - bringing in the power earlier, also brings it out earlier!
Rsmat
89
Oct 12, 2015 07:50 AM
Mc5506
Oct 5, 2015 09:57 PM
Fil
Sep 30, 2015 12:08 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
