3dr keeps stalling!!
Old Sep 8, 2005 | 06:26 PM
B11GNS's Avatar
B11GNS
Default 3dr keeps stalling!!
every now again, although its getting more common now , the car will just stall, it happens when i am driving along and then i have to come to a stop and i put my foot on the clutch the revs come down as they should but sometimes the revs just drop right down and the car stalls . Anyone any ideas?
Old Sep 8, 2005 | 06:34 PM
rsnissan's Avatar
rsnissan
map/tps/CPS or Phase sensor check the gaps on the last two and check the other sensors too.
Are you on L1 management?
Old Sep 8, 2005 | 06:39 PM
B11GNS's Avatar
B11GNS
yes, i am on level 1 at the moment. The red engine management light doesn't come on
Old Sep 8, 2005 | 06:46 PM
Ryan's Avatar
Ryan
does it only do it when warm?
Old Sep 8, 2005 | 06:53 PM
B11GNS's Avatar
B11GNS
Never noticed but now you mention it i think it is only when its warm
Old Sep 8, 2005 | 06:55 PM
Ryan's Avatar
Ryan
maybe its base idle is too low, the brass idle screw and locknut may have moved.
Do you know how to check this?
Old Sep 8, 2005 | 06:58 PM
Jim Galbally's Avatar
Jim Galbally
ditto what ryan said, if you pull the plug off the ISCV does the car stll.. if so you need to adjust the base idle higher.
also give the throttlebody, ISCV, idle adjuster bypass thingie etc. etc. a damn good clean with carb cleaner as it all gets gummed up pretty easy. we recently cleaned lennie's throttlebody up on his 24v and the idle jumped from hunting at 900rpom to 1800rpm idle it was THAT mingin!
Old Sep 8, 2005 | 06:59 PM
B11GNS's Avatar
B11GNS
Yes i do, i will check this tomorrow, cheers
Old Sep 8, 2005 | 07:01 PM
Jim Galbally
biggins, remember to give it a f**kin good clean whilst you're there take the screw all the way out too and blast inside the screw hole and blast the screw itself.
Old Sep 8, 2005 | 07:03 PM
Ryan's Avatar
Ryan
bally the bufty
Old Sep 8, 2005 | 07:11 PM
Jim Galbally
yeah, get the brasso out
Old Sep 8, 2005 | 07:49 PM
B11GNS's Avatar
B11GNS
will do, it could do with a dam good blow, like owner like car
Sierrasideways
Oct 8, 2015 06:37 PM
martynhomer01
Oct 1, 2015 12:05 AM
IainRS1700T
Sep 25, 2015 06:44 AM
jay030787
Sep 18, 2015 04:38 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
