ACT' Gauge Take offs , can i ....
Old Sep 8, 2005 | 05:45 PM
Tony Ryan's Avatar
Tony Ryan
Default ACT' Gauge Take offs , can i ....
Plumb an ACT Gauge take off into the back of a a Chargecooler unit before the plenum ? If so are they 1/8th NPT like on the plenum take off threads ??? Can multiple temps be read from these ACT Gauges or do you need one for each reading , i.e intercooler & plenum positions
Ta
Old Sep 8, 2005 | 06:03 PM
Billabong's Avatar
Billabong
If you're referring to Mike's ACT (CAT ) guage, then he does a dual input version (i.e. measure two seperate temps), otherwise the std one is one gauge-one temp'
Old Sep 8, 2005 | 06:15 PM
Tony Ryan's Avatar
Tony Ryan
Cheers for that Bill, im aiming to stick one in the back of the chargeclooer and one on the front to keep an eye on whats coming from the intercooler so a dual gauge would be just the ticket !
Tony
Old Sep 8, 2005 | 06:26 PM
Billabong's Avatar
Billabong
http://www.randbmotorsport.co.uk/sho...sp?ProductID=1 he does it in the newer blue backlight too.
Old Sep 8, 2005 | 09:56 PM
markk's Avatar
markk
just use a switch tony, use a double pole double throw and fit an extra sensor where ever you like that way you just flick teh switch and change over sensors - i do it for diff/gearbox temps
stevierob
Sep 7, 2015 07:09 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
