2 stage supercharger
new development from Antonov that allows a supercharger or other ancillary to be driven at 2 (or more) different different ratio's, allowing high boost at both low and high engine speed. could be the way forward
http://www.antonov-transmission.com/amm.htm
Antonov Mechanical Module
The Antonov Mechnical Module is based on Antonov original patents. The principle is to control the shift with the use of centrifugal force and axial thrust generated by helical gears under load. Therefore, they can work as autonomous self-adapting modules without the need for hydraulic actuation or electronic control.
Lubrication can take place with a small internal pump or using existing oil flows of the driven element.
Possible applications range from optimising an engine supercharger for a car or a boat, to improving car accessories and compressor drive, as well as for transmissions on small recreational vehicles.
The Antonov Mechanical Module is based on one of the first and fundamental inventions of Roumen Antonov. The heart of the device is a self controlling, fully mechanical shift system. It was the principal of balancing shift loads between a speed related load from a centrifugal mechanism and a torque related load from the helical gears. This balance enables smooth, clean shifts to be made across the load and speed range with shifting occurring at higher speeds under higher loads (see diagram).
This concept was initially applied to vehicle transmissions, but the very high demand for shift control did not suit the system characteristics. Work continues to apply the system to ultra low cost and micro cars, but the unit has already found application in areas where a simple two or three speed unit is required. Production is underway for a 2 speed supercharger drive and development work continues on a range of other applications including electric vehicle drives, all terrain vehicles and engine front end and accessory drives.
http://www.antonov-transmission.com/supercharger.htm
Supercharger Drive
Market Issues
Superchargers provide better drivability than turbochargers but to obtain good boost at low engine speeds leads to inefficient operation at high engine speeds
Variable speed drives (eg electric drive) have too high a powerloss to show significant overall gains
Problem Statement
How to achieve a compact, low cost and highly efficient multi-speed drive to a supercharger?
Antonov Solution
Use of a single AMM packaged into the input of the supercharger drive provides a 1.4:1 step up at lower engine speeds
No external controls are required but a simple solenoid control to allow the EMS to fine control the exact shift points for better engine control can be provided
High transmission efficiency ensures full use of the efficiency gains from better supercharger operation
Status
Manufacturing partner in place for low volume manufacture
Sales underway to niche vehicle makers and US aftermarket distributors
Discussions on higher volume applications underway
The compact Antonov Module complements the Rotrex unit to provide easy installation.
The addition of the 2 speed drive provides oustanding low speed engine torque
Supercharger Drive
Market Issues
Problem Statement
Antonov Solution
Status
what is j-tuner Steve?
is that a mag you buy in shops? does it often have interesting tech stuff, or just full of blitz adverts and shit?
The first few issues have actually been good with feature cars from Japan and it spends a lot of time on regaling info on the Jap car culture, rather than the UK's interpretation of it...
sounds interesting. working for a japanese company and having been there a few times it sounds quite interesting. i'll have to have a flick through when i'm back in england
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
Mc5506
Oct 5, 2015 09:57 PM
