Pro-alloy do it AGAIN!
Old Sep 7, 2005 | 04:32 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Default Pro-alloy do it AGAIN!
In a desperate attempt to help resolve my water temp issues, I realise that the best thing to do would be to box in all the intercooler and radiator (which was kindly confirmed by Mr Norris of NMS ), but not having time to do this (car is currently have a new clutch fitted for me to be 'Ring ready ), so I came up with the idea at the end of last week to have an auxiliary radiator made that will sit where the turbo cooler one sits normally, to suppliment the existing cooling. However, I decided to use the existing charge-cooler arrangement (which is currently looped back on itself with a U-bend), which means the head gets the benefit of the supplimentary cooling (which needs it most ). This meant that the radiator had to be a twin pass one, with both inlet and outlet on the same side of the charge-cooler / thermostat pipework. So Pro-alloy came up trumps and made it for me and it arrives to put on the car tomorrow. Will post pictures up when I get in in the morning, as I've got to shoot now .
Old Sep 7, 2005 | 04:37 PM
Damo V's Avatar
Damo V
Hmmmmm *strokes chin* Interesting ... Maybe this will become a standard item on Pro Alloys range, once testing has confirmed whether it works or not??
Old Sep 7, 2005 | 04:38 PM
NathR's Avatar
NathR
Good stuff Mike, hope it works for the trip at least.
Nothing like these last minute moifications is there!
Old Sep 7, 2005 | 04:45 PM
Spax's Avatar
Spax
Sounds like a nice mod,we await pics
Old Sep 7, 2005 | 06:43 PM
Sean Bicknell's Avatar
Sean Bicknell
Yeah, I like the sound of that to!!
Old Sep 7, 2005 | 06:46 PM
boycie_rst's Avatar
boycie_rst
sounds interesting
Old Sep 7, 2005 | 06:48 PM
Chris Honeywell's Avatar
Chris Honeywell
Get them pics up asap m8
and if they make anymore i will have one
for the bling value of course
Old Sep 8, 2005 | 07:40 AM
Mike Rainbird
Caraholic
Damo, yep it already has, the part number is MR007 .
Obviously the pictures have been taken with their intercooler set-up to give you an idea of dimensions / scale . May need your radiator lowering a fraction to enable fitting... .
As they say - every little helps - will be additional coolant volume as well as more air flow. It "may" even mean I don't have to box it all in (which will be a right pain in the arse to do - so the Pro-alloy boys would be relieved if this was the case ).
I hope it fits .
Old Sep 8, 2005 | 07:55 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
so after 10 years of u winging about act issues we are now going to have 10 years of ect issues from you mike roflol
Old Sep 8, 2005 | 07:59 AM
Stu @ M Developments's Avatar
PassionFords Creator
Old Sep 8, 2005 | 08:05 AM
Mike Rainbird
Caraholic
Tony,
The fun of owning a Cossie as far as I am concerned, is resolving these issues (even if they are self created ones ) .
Old Sep 8, 2005 | 08:09 AM
Sticky.'s Avatar
Sticky.
Old Sep 8, 2005 | 08:11 AM
Turbosystems
Super Moderator
warned you 5years ago on rsoc that atc issues at the expense of ect issues, ect was always a problem on our rs 500 when we raced in indonesia you are lucky you live in england ambient temps were 42 deg c + fook the car some one cool me down lol.
Next you'l be down at williams wind tunnel
Old Sep 8, 2005 | 08:14 AM
Turbosystems
Super Moderator
A to E you working your way down the alphabet mike heven help us when you get to P
act to ect to PMT roflol
Old Sep 8, 2005 | 08:23 AM
Mike Rainbird
Caraholic
Shame you haven't offered any constructive advice as you have experienced so much .
Old Sep 8, 2005 | 08:28 AM
Damo V's Avatar
Damo V
I like that, presumably those pics were taken before they welded some brackets onto it... I reckon thats gotta be more effective than the turbo return one??
Old Sep 8, 2005 | 08:36 AM
Turbosystems
Super Moderator
mike would you listen or would you just want to debate the advice lol.
My advice is to copy an rs 500
air damming is critical there must be at least a 10mm cap between rad and intercooler ,the rad must have this gap sealed to the intercooler.
If you remove the intercooler altogether ect will be fine
Old Sep 8, 2005 | 08:37 AM
Disabled Account's Avatar
Disabled Account
As they say - every little helps - will be additional coolant volume as well as more air flow. It "may" even mean I don't have to box it all in...............I hope it fits .
Mike, to quote a famous gay icon: "TEST dont guess"
I want a full ECT report on my desk after the ring trip
Old Sep 8, 2005 | 08:41 AM
wayneclayden's Avatar
wayneclayden
590 BHP/Ton
Mike Rainbird,
I'm glad i thought of this mod ...aren't you!!!
Old Sep 8, 2005 | 08:42 AM
Damo V's Avatar
Damo V
Turbosystems,
How would you go about doing this?
Old Sep 8, 2005 | 08:47 AM
wayneclayden
590 BHP/Ton
Damo V, you can buy foam draught sealer strips which are sticky on one side.. most diy stores have them
Old Sep 8, 2005 | 08:49 AM
Turbosystems
Super Moderator
take a look at an original rs500
Graceland's Avatar
Graceland
Team HOTHOT!
duct tape
Old Sep 8, 2005 | 08:51 AM
Mike Rainbird
Caraholic
My name isn't Phil .
There is already at least a 10mm gap (more like 20mm). I know I have to seal this in and will do so over the winter (or Wayne and the lads will ).
Doug, so what do you think I am doing then ? And thanks for replying to my text message about the speakers (not).
Wayne,
Good job I have a copy of all the email exchanges, as you said it was such a good idea you would claim it as your own . Perhaps I should be in charge of your R&D ?
Old Sep 8, 2005 | 08:52 AM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
looks a nice piece of kit
Matt
Turbosystems
Super Moderator
mike you clearly have ect issues lol
switch the heater on it will cost u nothing
Old Sep 8, 2005 | 08:56 AM
Mike Rainbird
Caraholic
Tony,
I HAVE to already do this, or the temp at the back of the head would exceed 110°C .
dumped's Avatar
dumped
Good luck mike
Could have put a serious setup in there to stop these issues lol
Old Sep 8, 2005 | 08:58 AM
Disabled Account
And thanks for replying to my text message about the speakers (not)...
No name displayed Mike..........so I could not be ar*ed to reply
Answer: Mission NOT Warfedale
Mike Rainbird
Caraholic
Martin,
There is absolutely NO more room for ANYTHING else after this, so I don't know what else I could have done .
Old Sep 8, 2005 | 08:59 AM
dumped's Avatar
dumped
cut the front end off .... worked a treat on my car lol
Old Sep 8, 2005 | 09:01 AM
RichardPON's Avatar
RichardPON
I thought Harvey didn't "do" aftermarket radiators?
Old Sep 8, 2005 | 09:06 AM
Mike Rainbird
Caraholic
He had to after I PROVED to him that the standard one wasn't up to the job with the intercooler in the way. The Pro-alloy / Radtec one is better at low speed, but no different at high speed, which proves it is an air-flow issue... However, the recovery rate of the standard one is quicker than the alloy ones. The supplimentary radiator is intended to be a "band aid" to get me past the weekend, not a fix (which will require sealing in the whole system to ensure air is not deflected around the radiator).
Old Sep 8, 2005 | 09:17 AM
Damo V's Avatar
Damo V
Dont have one to hand.....
I'll try that then thank you
Old Sep 8, 2005 | 10:05 AM
Turbosystems
Super Moderator
paint it all black then mike like a std rs500 with the correct paint of course not dulux non drip.
Old Sep 8, 2005 | 12:49 PM
Matt's Avatar
Matt
to add to uncle tonys advice mike......change the car for an rs500 but make sure you take some driving lessons first
praise the lord theres no islands on the nurburgring
Old Sep 8, 2005 | 12:59 PM
Mike Rainbird
Caraholic
Matt,
There is just before the entrance - make sure you go round it the correct way - the amount of times I've seen Brits forget which country they're in .
Old Sep 8, 2005 | 01:03 PM
Mike Rainbird
Caraholic
Best you get some in ready .
Old Sep 8, 2005 | 03:28 PM
wayneclayden
590 BHP/Ton
Mike Rainbird, does it fit??
looked a little tall to me......
If it dosen't fit I will reveal to the world that it was actually your idea!!
Old Sep 8, 2005 | 03:57 PM
Turbosystems
Super Moderator
roflol
