cossie group a coil
Old Sep 7, 2005 | 10:23 AM
b14dave's Avatar
b14dave
Default cossie group a coil
Has anyone fitted a group a coil to there cossie has it made any difference,what are the advantages.
Old Sep 8, 2005 | 11:23 AM
foreigneRS's Avatar
foreigneRS
Testing the future
yes and no. supposed to give a higher voltage than std which should give a stronger spark. to me, the only advantage is that they're cheap and new, so should be reliable
Old Sep 9, 2005 | 08:27 PM
Mr.Ford's Avatar
Mr.Ford
i think you're right!
I've also got an Group A Coil, and i've never noticed any big difference...but I think it's a nice ad-on to a fast cossie
Old Sep 11, 2005 | 02:55 PM
cossy abuser's Avatar
cossy abuser
If you are running boost levels of 2Bar and above you will need a group A coil or the spark will be blown out by the charge entering the combustion chamber, feels like the rev limit is set at 4000 revs
Old Sep 11, 2005 | 04:12 PM
richard_xr2i1800's Avatar
richard_xr2i1800
are they a straight swap
Rich
Old Sep 11, 2005 | 04:20 PM
cossiescott's Avatar
cossiescott
Bolt on in the same place but the connectors are different!
Old Sep 11, 2005 | 06:11 PM
RSCosworth's Avatar
RSCosworth
how are the connectors connected?
I bought one recently but haven't installed it since I didn't know how
Old Sep 11, 2005 | 07:01 PM
cossy abuser
just look at the old connections
one goes to positive marked +
one goes to negative marked -
HT lead is self explanitary
Old Sep 12, 2005 | 10:01 AM
b14dave's Avatar
b14dave
just bought one as spark keeps being blown out arrived today so hope makes difference.
Old Sep 12, 2005 | 11:09 AM
foreigneRS's Avatar
foreigneRS
Testing the future
btw, your spark isn't being 'blown out' - it's just that there is too much resistance in the air between the 2 electrodes meaning that the voltage isn't high enough for the spark to be able to jump the gap there. it will be finding an easier path to earth somewhere else. it could also be cured by making sure that all other components in the ht system are in good condition.
if you really want a stronger spark, go to coil pack or coil on plug
Old Sep 13, 2005 | 10:28 AM
RSCosworth's Avatar
RSCosworth
there are four pins + HT lead on mine?
Old Sep 13, 2005 | 04:35 PM
Dean Saff's Avatar
Dean Saff
Your not meant to notice a difference as they dont increase you BHP just let you run a bigger gap, it may idle a little better too with the bigger gaps.
Old Sep 13, 2005 | 04:48 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
I was told that since they are not oil filled like ordinary ones, they can overheat though
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
