PLEASE HELP honda civic kirbd at 60, wheel slanted
bassically went stormin round a bend fucked up hit kirb rear near side wheel now slanted. was like | that now like this \ wot hav i broken, how much 2 fix? PLEASE ADVISE ME!!! thanx.
lol just read wot iv put havnt explained problem very well have i. the wheel isnt strait anymore... um how do i explain. lol like i sed was like this | <--- strait now its like this \ <---- slanted
Dunno what year Civic you have but at the very least you will have bent a rear wishbone. Have a check under the back of the car tomorrow and have a look around. Something will be bent or kinked somewhere.
Start from the point of impact on the wheel and look closely at all the connecting bits to it.
Once you know what it is thats bent a trip to a breakers yard will be next on the cards.
I'd have a complete stab in the dark and say if your wheel is okay and not bent then your looking at around £60+ to fix.
Hope that helps you calm down a bit
Tony
Tony
have a look @ the wheel that is bent from under the car and compare it to the other side and you should see if any thing is different eg bent snapped ect
that or go to you local garage and get them to put it up on a ramp and have look and see if they can fixit m8
meen while just get pissed and forget about it untill the morning it normal works for me
Bad luck mate, its sounds like it could be expensive
... but PMSL at your sig:
"Drive it like you stole it!"
yeah, but after you crash it your supposed to run off or torch it. LOL!
steve
steve
Karl @ FPT
Sep 21, 2015 11:17 AM
Adam Graham
Sep 6, 2015 06:04 AM
