Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Help!!!, Prob with my escort 1.8 Si mk6
Old Sep 2, 2005 | 07:00 PM
JsTurbo's Avatar
JsTurbo
Default Help!!!, Prob with my escort 1.8 Si mk6
Hello everyone.
Right to the point lols.
I just got this car a couple of months ago, its a escort mk6 1.8 Si, 115bhp version.
When i accelerate up hills or when i drive the car hard just the length of a road, when i come to brake and dip the clutch the revs will stick at 3k rpm. They will only come down once i bring the clutch up so it bites and then it will calm down. But as soon as i drive again at say 2k rpm same again when i dip the clutch the revs will creap up on there own to the 3k mark. Whats wrong!!!!!!!, this only happens when the caris hot and when i have driven hard, but this should not happen still.
2) aslo when i drive at 2k rpm or when the revs drop past 2 rpm there is a rattle coming from under the car. Maybe the cat. bt dunno. Im not loosing any performance and as soon as the car is over 2k rpm there is no noises at all.
If anyone can help i would appreciate.
Thank you,
James
Old Sep 3, 2005 | 07:13 AM
Paddy's Avatar
Paddy
Legend
The unhappy revs sounds like a sticky throttle or a potentiometer thats on the way out
As for the vibration, without listening to it, it's impossible to tell could be anything although exhuast clamps like to come loose or spin round so the bolt ends are vibrating against something
Old Sep 3, 2005 | 09:24 AM
JsTurbo's Avatar
JsTurbo
thanks mate,
I will havea look at it. Cheers,
Old Sep 3, 2005 | 02:38 PM
BM08's Avatar
BM08
1st problem is either idle control vavle or throttle position sensor, i had same problem with my escort gti, a new throttle sensor sorted this out
Old Sep 4, 2005 | 08:51 AM
Paddy's Avatar
Paddy
Legend
There ya go was trying to think of the modern term for potentiometer that would be in the haynes manual or the muppets at the motor factors/ford parts would know
I'm getting old
Old Sep 4, 2005 | 01:53 PM
JsTurbo's Avatar
JsTurbo
Thanks people,
I will have a look and let you all know,
Old Sep 4, 2005 | 04:02 PM
Moondust_crust's Avatar
Moondust_crust
does this on mine mate exactly as you have said , ive got a 1.6 si, although my revs havent stuck for over a month now , the rattle you hear is the scuff plate on the bottom of the cat , they tend to rattle around a bit. hope this helps, cheers mark.
Old Oct 6, 2005 | 09:40 PM
Turbo Pez's Avatar
Turbo Pez
Does it on mine (same car 115ps si), it seems to come and go, mainly does it when cold! its done it for the 2 years i've had mine, still runs fine so ain't gonna fix it ,
p.s.
if your clutch goes, get a garage to do it coz its a c*nt of a job, just finished doing mine today, found it easyer taking the engine out my turbo!!
Old Dec 3, 2005 | 04:02 PM
Toniboy's Avatar
Toniboy
A up,
iv'e got gti and just started doing it on mine. changed the air flow senser but made problem worse, did you change the thottle position senser-and did it work,
thanks T,
Old Jan 11, 2006 | 12:51 PM
andy_st200's Avatar
andy_st200
its nearly always the idle control valve their shit on the mk6 and go all the time
Old Jan 19, 2006 | 01:12 PM
mart.rs's Avatar
mart.rs
ive got the same problem on mine too,ive had the car for just under 3 weeks,can be a little annoying!!! mines an 1800 si n reg i love it,except this idling problem!!!!
Old Feb 6, 2006 | 09:24 AM
nick_GTI's Avatar
nick_GTI
Deffo idle control valve my GTi was doing exactly the same thing. Took the valve of cleaned it out, coated it with good old WD40 then reset ecu. Make sure you reset ecu cus mine ran a bag of sh*t till i reset it.
Old Feb 9, 2006 | 09:19 AM
Toniboy's Avatar
Toniboy
hi mate, iv,e got a gti and mine started doing the some thing about 4 mounth ago. 3000k plus rattle under the car. i had the mas air flow changed plus spayed the lot with wd40, but did not help in anyway. i disconnected the battery to reset the ecu and it seemed to do the trick the revs went back to normal. but when the car got hot it started to lose power until i put the accelorater to the floor and then it would put ya back in ya seat. the car is in at FORD at the moment for the 6th time for the same thing. i dont no if they no what they are doing?. hopefully yours is something simple. the cars due back any day now so i'll get back in touch with ya and let ya know what the problem was, thats if they fix it.
Toniboy
Old Feb 20, 2006 | 10:40 AM
Turbo Pez's Avatar
Turbo Pez
I just bought a new idle control valve of ebay for mine mk6 115ps, seller called the-ford-shop, sells them all the time, I did clean mine old 1 and did make it beta for a few months, but started doing it again!!
Fitted the new 1 and it idle at 2500rpm, so i disconnected the battery for a couple of hours to reset the ecu, reconnected the battery, started it up, idles perfecty, sat a 1500rpm on cold start, took it for a spin, now sits just below a grand!!!
New valve cost me 48.98 including p+p, from the seller "the-ford-shop" there always seller them!!
Old Feb 27, 2006 | 12:22 PM
silencer's Avatar
silencer
so this could be a really stupid question but the idle control valve where bouts is it and is it an easy job to do thanx..
Old Mar 3, 2006 | 09:32 AM
Turbo Pez's Avatar
Turbo Pez
Its stuck on the inlet manifold, on the side close to the engine, only 2 bolts, but a complete nitemare to get to! best to do when engine cold as well!!!
Old Jan 7, 2010 | 02:06 PM
muellergb's Avatar
muellergb
Hello there,
Be gentle with me pls.I've just joined this forum.I've got a 1997 1800si (115 bhp) and I'd like to know the clutch drive plate diameter,is it 210 or 220 mm.I need a new clutch.Where can I go for best price.Many thanks in advance.
Old Jan 9, 2010 | 10:59 PM
MrF's Avatar
MrF
The rattle also could be the heat shield beside the fuel tank, mine had ripped metal and was flapping around and needed to be resecured, after that...no more noise
Old Nov 12, 2012 | 08:19 PM
maxwax's Avatar
maxwax
good look mate with the idie ive got the 115hp gti and idie stays at 1500 rpm ive changed icv senors and no airleaks ive give up on it lol
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
FlashRS
Sep 14, 2015 12:36 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
Bighandsuk
Sep 2, 2015 05:23 PM
