Green Cosworth Injectors - Anybody know their stuff??
Old Sep 2, 2005 | 05:25 PM
SafeChav's Avatar
SafeChav
Default Green Cosworth Injectors - Anybody know their stuff??
Going EFI soon on S2 lump, and ive acquired what would seem to be some light green cossie injectors, but im not sure of the part number?
on the green plastic body the part number is 280 150 743
anybody know if these are cossie injectors? and if so if theyre the 355 or 803 capacity or whatever they are
im sure theres someone out there more knowledgable than me
Old Sep 2, 2005 | 08:18 PM
richm's Avatar
richm
these aren't cossie injectors, and they don't appear in the listings I have got to give you an indication of flowrate
cossie "light greens" are 0 280 150 355 , "dark greens" are 0 280 150 803
Old Sep 3, 2005 | 03:14 AM
SafeChav's Avatar
SafeChav
cheers mate
one word.....B*LLUCKS
thanks for your help though, at least i wont put them in thinking theyre up to the job and pop the engine
Old Sep 3, 2005 | 04:19 AM
Wazzzer's Avatar
Wazzzer
you won't be able to use any cossie injectors with the FRST EFi setup, they're the wrong impedence
You'll only be able to use them if you're going full cos management
Old Sep 3, 2005 | 08:35 AM
Jay,'s Avatar
Jay,
Sponsor
the light greens that you have my mate had a set in his cossie on a stage one chip there the same job as 355s they work fine he was runin 18 psi for 2 years just gone stage 3
jay
Old Sep 4, 2005 | 12:50 PM
SafeChav's Avatar
SafeChav
ill have to measure the impedence, as long as the impedence is higher, not lower it shouldnt present any problems.
Jaycos!!! Nice one!! ill give them a try when i convert then
big_Rad
Sep 15, 2017 09:36 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Russ Hill
Aug 31, 2015 06:44 PM
Aug 14, 2015 07:29 AM
