MFI to EFI conversions.......
Old Jun 30, 2004 | 10:13 AM
keithG666's Avatar
keithG666
Default MFI to EFI conversions.......
.....can someone give me the full list of parts required in order to do this pleae?!?!?!
Old Jun 30, 2004 | 11:01 AM
keithG666's Avatar
keithG666
Old Jun 30, 2004 | 11:03 AM
zvhturbo's Avatar
zvhturbo
ECU
Loom
Injectors
MAP sensor
Coil Pack
Ignition leads
Inlet manifold
Inlet manifold conversion plate (or use EFI head)
Crank sensor inc pick up hardware
Someone else finish it off for me please.
Old Jun 30, 2004 | 11:12 AM
DanS's Avatar
DanS
Why would you want to change the management keith?
Old Jun 30, 2004 | 11:46 AM
keithG666's Avatar
keithG666
plans a foot.........oh...and chatter
Old Jun 30, 2004 | 11:48 AM
Ryan's Avatar
Ryan
keith doing a management chage
i can just see the future post now
Old Jun 30, 2004 | 12:17 PM
keithG666's Avatar
keithG666
ye of little faith!!!
Old Jun 30, 2004 | 05:04 PM
Scott R's Avatar
Scott R
Scott R's Avatar
Scott R
Parts will depend on if you want Cossie stuff or go for an alternative management, ie Omex or Autronic.
Cossie stuff,
Throttle body ( can use RST one if mods are made to Efi inlet)
Idle speed control valve( either remote or on throttle body)
Throttle position sensor
Air charge sensor
Water temp sensor
Injectors ( colour depends on what tune stage you go for)
3 Bar map sensor( only if you want to run more than 1 bar boost)
Ignition amp and heat sink
Modified Dizzy or use a pick up off the cam pulley and coil packs
TDC sensor and lead and pulley with 4 pick up points. ( or you can use 1.8 CVH stuff thats slightly modified to fit)
L8 Ecu and loom ( get a new loom made from SCC, saves ALOT of hassle in the long run)
EFI Inlet with fuel rail
4x4 Fuel Pressure regulater
And someone friendly to do all the work for you
Old Jun 30, 2004 | 06:17 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Default Re: MFI to EFI conversions.......
Loom Cosworth 2wd / 4x4
ECU Cosworth 2wd / 4x4
Pectel Board + Plug for fittment
Crank Sensor Cosworth 2wd / 4x4
Alternator
Alt Bracket + Tensionor + Bolts
Altenator Belt
Bottom pulley
Crank pickup sensor bracket
Throttle Body Cosworth 2wd / 4x4
Ignition Amplifier + Heat Soak Cosworth 2wd / 4x4
Injectors Cosworth 2wd / 4x4 start @
Inlet Manifold Fiesta / Escort EFI
Laser Cut Phase Disk
Charge Air Temp Switch Cosworth 2wd / 4x4
Fuel Rail Fiesta/Escort EFI + Bolts
Idle Valve Cosworth 2wd / 4x4
Throttle Position Switch Cosworth 2wd / 4x4
Map Sensor 3 Bar
Fuel Regulator Cosworth 4x4
Distributor
Water Temperature Switch Cosworth 2wd / 4x4
Inlet manifold bolts
Throttle Body Gasket
Bottom Pulley Washer
Throttle Cable
Throttle bracket
Water Temperature Sensor convertor
ACT sensor convertor
Bottom Sensor
Top Sensor Bracket
Top Pulley
Rocker Cover
Fuel Filter
Fuel Filter Bracket
Fuel Lines
Inlet Manifold Gaskets x2
Map Sensor Bracket
MFI - EFI Convertor Plate
Maytee this is my list hope this helps
Regards
Jano
Old Jun 30, 2004 | 08:31 PM
Ginge !'s Avatar
Ginge !
just finding my feet
get omex from gary
Old Jun 30, 2004 | 08:36 PM
TIL13R's Avatar
TIL13R
Keith just buy a cossie by the end of this you will have all the parts anyway!
Old Jun 30, 2004 | 08:43 PM
Ginge !'s Avatar
Ginge !
he cant control a cossie, made him cry home to mummy before
Old Jun 30, 2004 | 08:46 PM
TIL13R's Avatar
TIL13R
PMSL
steve.rst
Mar 15, 2016 08:01 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
stevierob
Sep 7, 2015 07:09 PM
